1. LailaAK's Avatar
    I have been using my Verizon Note 5 with AT&T SIM Card for a few days. It can access AT&T's 4G LTE network(with the 4G logo showing up next to the signal bars). If I'm in the downtown area, I get around 23mbps down and 5mbps up, which is comparable to Verizon's 4G network.
    My question is.... what did Samsung add to the Note 5 that allowed this? I took the same AT&T SIM Card and put it in my old Note 3 and Note 4 and they could only pick up AT&T's HSPA+ frequency. If I put the same SIM card back into the Verizon Note 5, it immediately picks up AT&T's 4G LTE. The APN settings for AT&T are identical on all three Note phones.
    10-18-2015 12:56 PM
  2. TheLastPanda's Avatar
    Check the cellular 4G LTE bands on the Note 3 and 4. AT&T current bands are 2,4, and 17. VZR current bands are 2,4,13. It could be that bands 2 and 4 are not available in your area.
    This is the reason why I bought a AT&T Note 5 for $40 more to use on AT&T network even though all VZW phone are unlocked.
    EDIT: according to VZW website the Note 4 only has bands 4 and 13 so AT&T must be using band 2 in your area.
    10-18-2015 01:16 PM
  3. LailaAK's Avatar
    thanks! that makes sense. I guess my old Note 3 and Note 4 just don't have band 2.
    10-18-2015 01:27 PM
  4. TheLastPanda's Avatar
    you can use app called LTE Discovery to see what band you're using in different areas
    Sent from my SAMSUNG-SM-N920A using Tapatalk
    10-18-2015 01:32 PM
  5. LailaAK's Avatar
    Thanks! I installed that app on my Verizon Note 5.
    When I use a VZW SIM, it reports LTE Band 2.
    When I take the VZW SIM out and insert the AT&T SIM, it also reports LTE Band 2.
    So I guess as long as I'm in AT&T service area with bands 2 or 4, my Verizon Note 5 will pick up AT&T LTE service.
    10-18-2015 05:42 PM
  6. Tony Griffie's Avatar
    did you have to change any of you apn setting to get lte on your note 5.
    11-03-2015 08:50 PM
  7. adam costa's Avatar
    What apn settings? I've tried about a dozen and none seem to work for me...
    01-07-2016 08:26 PM
  1. Instagram pictures not saving to my gallery?
    By ScarlettOhara777 in forum Samsung Galaxy S5
    Last Post: 02-17-2018, 11:58 PM
  2. My LG G3 only gets 2G (Edge) signal, how can I fix it?
    Last Post: 12-17-2016, 08:19 PM
  3. I keep getting these popups at random times, is it a virus?
    By Meesha Lin in forum General Help and How To
    Last Post: 11-18-2015, 11:06 PM
  4. Galaxy S5- Help using Scrapbook, Instructions to begin
    Last Post: 10-18-2015, 02:14 PM
  5. Why Can't I connect to the internet after removing CM Security?
    By RaymondLangley in forum Android Security Talk
    Last Post: 10-18-2015, 01:16 PM
