1. KiwiCoalBattery's Avatar
    is there a wireless charger that will let me to place the Note 5 correctly even if I'm drunk as a skunk or half asleep or in a completely dark bedroom? Sadly, I've been in all three of those situations lately. I have a regular non-fast charging Samsung wireless charging pad. I always missed the mark(only in those three situations).
    I want a wireless charging pad(doesn't have to be fast charging) that will allow me to put the Note 5 on it correct just by feel. Or a slot that kind of just drops it... does such a thing exist? Thanks!
    10-20-2015 01:33 PM
  2. Jay Sacks's Avatar
    Tylt Vu has been the best wireless charger I have found. Works portrait and landscape..no noise and no heat.
    Sent from my SM-N910V using Tapatalk
    10-20-2015 01:37 PM
  3. KiwiCoalBattery's Avatar
    cool.. thanks! I'll check it out. Even the name "Tylt Vu" looks
    like it was a name they came up with while drunk.
    just kidding.
    TonyLibations likes this.
    10-20-2015 01:54 PM
  4. JohnnytheK's Avatar
    I have the Spigen model that is also a stand. It seems to not mind how you place the phone, horizontal or vertical.
    Sent from my SM-N920T using Tapatalk
    10-20-2015 02:04 PM
  5. starwarz's Avatar
    I HAD the Spigen model that was a stand as well, but the only way I could get it to start charging was to place it in landscape position, then once it started I could quickly change it to portrait position and it would charge. If I placed it in portrait mode first, the LED indicator would flash red then blue over and over and not start charging. I did this both with and without a case. I even had Spigen send me a replacement, which did exactly the same thing. Returned them both.
    10-20-2015 02:18 PM
  6. Gray Area's Avatar
    Title of this thread is hilarious!
    Posted from my Beast Galaxy Note 5
    DEVICE HISTORY (since they got smart)
    PHONES: Galaxy Nexus, LG viper, Galaxy s3, HTC Evo 4g, Galaxy Note 2, Galaxy s5, LG G-Flex, Galaxy Mega 6.3, Galaxy s6 edge, Galaxy Note 5. TABLETS: Galaxy Note 10.1 gt-n8013, Galaxy tab 3 7.0. Lenovo tab2 A8 50 WATCH: Galaxy gear
    10-20-2015 02:53 PM
  7. zero157h7's Avatar
    Did you have a case on it? I have had no problems on my Itian charger which is the same charger with a different logo on it. If I had my Pierre Cardin case on I had to charge horizontally because of the seams. Without that charger it worked great.
    10-20-2015 03:31 PM
  8. zero157h7's Avatar
    OP,
    The Vu is awesome but a little pricey. The Spigen mentioned by others is more than sufficient though it's a little uglier than the Vu. There are also chargers like the Spigen with other brands on it that are identical and could be even cheaper.
    What you want to do it search Amazon and/or Ebay and you want to search for "qi 3 coils" or something similar. The chargers that have 3 coils means that there are multiple points of contact and it ups the chances that different phones are going to sit right on it. Then look at the pictures and pick one that stands up instead of one that lays down. The great thing about them standing is that there is usually a lip for them to sit on which will keep them always in the same place thanks to gravity.
    Finally, I would recommend going as cheap as you can. We are starting to see 3rd party fast wireless charging devices now and I would not be surprised if we see some fast wireless chargers that stand and have the multiple coils in the next couple of months. You might be tempted to buy another charger when that happens.
    10-20-2015 03:37 PM
  9. KiwiCoalBattery's Avatar
    OP,
    Thanks! I was just about to ask what qi 3 coils mean... I learn something new every single day here.
    10-20-2015 04:23 PM
  10. Carlo Villa's Avatar
    Try the Verizon charger, it works really well.
    11-04-2015 12:30 PM
  11. Mark Valentine's Avatar
    I'm Not sure what problems you're having. But I'm using the Samsung wireless charging pad without any problems.
    11-04-2015 12:44 PM
  12. undercovergeek's Avatar
    Choetech fast charge works for me, anyway I put it on it charges.
    11-06-2015 09:38 AM
  13. maskedcarrot's Avatar
    The Verizon QI charger which is a stand and not a puck, works just great! it may not be a fast charger, but it still works really good. Never have an alignment problem with it.
    I bought the Cheotech Quick QI charger puck from Amazon and ended up returning it. It made my phone really hot when charging.
    11-06-2015 11:46 AM
  14. tubbz the bull's Avatar
    Any 3 coil charger.... i have a choetech and it works wonders
    11-06-2015 01:38 PM
  15. Carl Bloom's Avatar
    Another drunk as a skunk note 5 user here, Tylt Vu works great for me. Toss it on and it charges. Best one I've tried.
    11-06-2015 11:05 PM
  16. Shaun Coleman's Avatar
    Spigen has a wireless desk charger does great, 3 zone so no need to figure out how to set. Grabs 100%
    11-07-2015 01:20 AM
  17. BettysNephew's Avatar
    I have a S View cover on my Note5 and could not get the Samsung "hockey puck" charger to work reliably with the cover on or off. It did the same thing on several of the same chargers. Returned it to cell provider and got a Tylt Vu. It also would not work in the portrait position with the case on but did work in that orientation with no case. Kind of a pain taking it out of the case to charge. After finding this thread, tried it in the landscape position with case on and 100% function even when alcoholically impaired! Ding, ding, ding. I have a winner.
    11-07-2015 07:43 AM
  18. Carl Bloom's Avatar
    Mine charges in landscape in a case with no problems at all, but in portrait if I just set it on the Vu its hit or miss. But if I put it against the charger and hold it about a half inch about the lip where the phone sits,it will start to change then just let it slide down to the bottom and it stays charging all night. Kinda strange but it works every time. Normally though I just charge in landscape.
    11-07-2015 08:50 AM
  19. rtronick's Avatar
    I had the same problem with the Spigen charger
    My Verizon charger also works great!
    11-07-2015 04:27 PM
  20. Carlo Villa's Avatar
    Here it is, I leave it overnight and gets fully charged.
    I think it costs $50.00
    11-07-2015 04:56 PM
  21. BamaMomRollTide's Avatar
    I have a Pelican protection cover on my Note 5. I use the Samsung wireless charger ($50 at ATT).
    I have to place my phone "landscape" with the "charger cord" coming out the top of the wireless (can you picture that?)
    More detail: imagine the charger is a clock and the cord is at 12:00. I have to place my phone landscape (home button on right side).
    I have to set the phone down with a slight "thud" down on the charger...centered...and allowing me to see the "solid blue". If I don't do the slight "thud" then only the blue light goes on, but no charging takes place.
    Hope this helps.
    11-07-2015 04:58 PM
  1. Replies: 96
    Last Post: 11-21-2015, 05:21 AM
  2. S6 on T-Mobile - Calls Going Direct to Voicemail Despite Full Bars
    By biggbrother2 in forum Samsung Galaxy S6
    Last Post: 11-15-2015, 09:27 AM
  3. Replies: 15
    Last Post: 11-05-2015, 10:40 PM
  4. How do I stop my phone from sending incoming directly to voice mail?
    Last Post: 10-20-2015, 03:48 PM
  5. Aukey Quick Charge Car charger - caution
    By note-4 in forum Android Auto
    Last Post: 10-20-2015, 02:46 PM
