1. relaxedninja11's Avatar
    I saw a 4000 MaH power pack for 30 bucks its 5volts is it safe to use on my note 5?
    10-20-2015 05:11 PM
  2. B. Diddy's Avatar
    Assuming it's not terrible quality and won't explode on you, any of these kinds of power packs is safe to use for your phone. Phones can't be "overcharged"--they'll draw only as much current as they need.
    10-21-2015 02:52 AM
  3. jmy7213's Avatar
    5 volts or 5Mah? Most chargers are 5v but vary from (.500 to 2.1a) Ive used a iTaste MVP electronic cigarette battery before to charge my phone. It has a usb port on the bottom for that purpose. It throws about 8 volts but the amps are at. 2.1 which was fine with my phone. Charged
    Sent from my Samsung Galaxy Note V
    10-21-2015 08:49 AM
  4. dpham00's Avatar
    Spec wise you would be fine. Though honestly there are better deals out there, assuming that you are in the usa
    Sent from my Verizon Samsung Galaxy Note 5
    10-21-2015 10:24 AM
  1. 6p & 5x Double tap power for camera feature on Nexus 6?
    By ryancell in forum Nexus 6 Rooting, ROMs, & Hacks
    Last Post: 01-17-2016, 08:52 PM
  2. shouldn't power saving mode turn off once I plug the charger?
    By LailaAK in forum Samsung Galaxy Note 5
    Last Post: 10-20-2015, 01:58 PM
  3. S6 Keeps powering off and wont charge
    Last Post: 10-20-2015, 06:12 AM
  4. Power button and up volume button issues
    By thellamapaul in forum HTC One M8
    Last Post: 10-19-2015, 03:08 PM
