I have a note 5 that in the last week it seems to drain very quickly. When I check gsam to see what is causing the problem it says that the majority of the battery life is being used by the android system. I have rebooted it a few times in the last couple days to see if that would help but it does not seem to be doing any better. I have not installed any new apps on it recently so I was curious what I can do to make the android system take up less battery life? Thanks!
