1. look-fast's Avatar
    hi does anyone have this same issue?
    the media volume does not work in sync when Mute or Sound is turned on?
    Media remains at last set volume no matter which mode... is there a solution or is it supposed to be like that pls?
    Attached Thumbnails Sound (tones, notification)  issues-1445673836672.jpg   Sound (tones, notification)  issues-1445673851237.jpg
    10-24-2015 04:06 AM
  2. franko515's Avatar
    It's supposed to be that way. Media only comes into play if you play music or videos
    10-24-2015 07:14 AM
  3. gozirra's Avatar
    Or alarms or games or... pretty much anything that isn't a notification, system alert, or ringtone.
    10-24-2015 10:48 AM
  4. look-fast's Avatar
    ok Thanks
    10-25-2015 04:12 AM
  5. look-fast's Avatar
    i think i have a faulty set then. .. the whatsapp n messages notifications come in thru the media settings..
    10-25-2015 04:13 AM
  6. gozirra's Avatar
    That would be a bug (on purpose) with the WhatsApp app then, circumventing the design feature of "if I turn down Notifications volume, I won't hear Notifications" - Google frowns on that in the upcoming OS. For now all you can do is report it to WhatsApp and they can ignore/change it as they desire. It isn't anything faulty with your phone. Don't get rid of your phone over some app, ever.
    look-fast likes this.
    10-25-2015 02:08 PM
  1. SMS issue!
    By Francisco Rivas in forum Samsung Galaxy Note 5
    Last Post: 10-24-2015, 12:42 AM
  2. Replies: 0
    Last Post: 10-23-2015, 11:40 PM
  3. Specific notification settings for specific apps - Galaxy S6
    By Jeetkunelo in forum General Help and How To
    Last Post: 10-23-2015, 08:06 PM
  4. Replies: 0
    Last Post: 10-23-2015, 05:34 PM
  5. Is there an issue with the S6 and WiFi connectivity?
    Last Post: 10-23-2015, 04:58 PM
