1. AC Question's Avatar
    So my camera works fine but at the top left corner is the settings button and when i click it i only see the settings for a split second and it just takes me out. I dont know how to fix it. I cant view my settings for my camera while im on the app because once i try to click the little settings icon it just closes it . Anyone else have this problem ? How would i fix this??
    10-29-2015 03:07 AM
  2. H3aTeRzz's Avatar
    Hiya,
    Try going to Settings>Device>Applications>Application Manager
    Scroll over to "All"
    Goto Camera in the list
    Clear Cache > If that doesn't work, go back to Camera Setting (using the above method)
    Then Clear Data
    Hope this helps!
    10-29-2015 08:21 PM
  1. Replies: 1
    Last Post: 07-05-2016, 03:42 PM
  2. Replies: 0
    Last Post: 10-29-2015, 02:13 AM
  3. Where is my clip board located I'm my galaxy samsung
    By Tracy Hultquist in forum Ask a Question
    Last Post: 10-29-2015, 01:40 AM
  4. How do I get my camera to work on my LG G Stylo?
    By AC Question in forum LG Android Phones
    Last Post: 10-29-2015, 01:22 AM
  5. How can I overcome a sensor problem on my Xperia Z?
    By AC Question in forum Sony Xperia Z
    Last Post: 10-29-2015, 01:17 AM
