1. chubby22's Avatar
    Was wondering if anyone is having problems when charging their Note 5(Verizon)? Everything was working fine, then 2 nights ago, it suddenly started acting weird. I tried 2 different cables, and all it does is make that sound when you connect the cable. Only way to actually charge device is to shut it off... Also this weird popup started at the same time.. Screenshot included...
    11-03-2015 11:26 PM
  2. B. Diddy's Avatar
    Power Sharing is the ability of the phone to charge up another device by connecting it via USB cable, and using the Power Sharing app. In your situation, I wonder if there's an issue with the USB cable you're using, or perhaps the phone's microUSB port. Make sure the port is clear of debris; if that doesn't help, then try a different USB cable.
    chubby22 likes this.
    11-04-2015 01:09 AM
  3. chubby22's Avatar
    I tried your suggestions. Weird thing is that the Samsung cables work on my wifes phone but not mine. Tried a different cable non samsung, and it works so far. Thanks again!!!
    B. Diddy likes this.
    11-04-2015 10:28 AM
  4. AdamHLG's Avatar
    I had this issue. And then no power cables would charge at all or even register that the cable was connected (tried 3 different chargers and cables) and the phone would only charge via wireless charging. And then it started saying dock connected repeatedly. The phone was possessed. I exchanged it under warranty and the new unit is flawless. I'll never know if it was a software bug or hardware failure. Seemed like a hardware failure.
    11-04-2015 11:26 PM
  5. B. Diddy's Avatar
    It might have been a problem with the microUSB port. Glad you got it replaced!
    11-04-2015 11:55 PM
  6. chubby22's Avatar
    Not sure what was happening with my phone. Used the original cables and they work fine now. Also, battery life increased. Currently at 21hrs, have 40% left. Approximately 14 hrs left...
    11-05-2015 12:33 PM
  7. B. Diddy's Avatar
    Perhaps there was some crud in the microUSB port that got cleared out in the process of plugging and unplugging your various cables.
    11-05-2015 07:15 PM
  1. How do I fix my Samsung sync issues?
    By Shawna Danea Sears in forum Samsung Galaxy S5
    Last Post: 11-04-2015, 05:03 PM
  2. Turbo charging trickles when phone is being used
    By dpham00 in forum Motorola Droid Turbo 2
    Last Post: 11-04-2015, 01:13 PM
  3. Youtube issues
    By perezs07 in forum LG V10
    Last Post: 11-04-2015, 11:59 AM
  4. Anyone having MMS issues on Verizon on the %X?
    By cunninsa in forum Nexus 5X
    Last Post: 11-03-2015, 10:19 PM
  5. Issue with Nexus 7 2nd gen wifi and rotation
    By danial80 in forum General Help and How To
    Last Post: 11-03-2015, 05:10 PM
