1. TheLastPanda's Avatar
    I just got my free wireless charger. I have a thin Spigen clear case on it as well as carbon wrap from Slickwraps. When I put it on my wireless charger it will charge for 20-30 seconds then my phone will stop charging. If I have the screen on it will give me message saying "wireless charging has been paused". When the wireless charging stops, the charger will go from solid blue lights to flashing blue lights as if it senses the phone is still on it.
    I tried my coworker's phone who also has a Spigen case but a different one. His phone works flawlessly on the same wireless charger.
    Could it be that the wrap on the phone is interfering with the charging. I find it hard to believe. Does anyone have experience with wraps on wireless chargers.
    11-04-2015 11:30 AM
  2. TheLastPanda's Avatar
    I guess I'll call SlickWraps today and see if they're aware of the issue.
    11-05-2015 08:18 AM
  3. ColoradoHiker's Avatar
    Panda,
    There are multiple threads on this problem, some people having issues similar to yours, others do not. Some have tried changing the cable to a heavier cable, other chargers seem to prefer specific orientations.
    I am using the Samsung fast wireless charger with the Otterbox Defender case, which is one of the thicker cases out there, and have no issues so far.
    11-05-2015 08:36 AM
  4. TheLastPanda's Avatar
    Panda,
    Others are having problems with Wrapped phones or chargers in general?
    I believe my issue is directly related to my SlickWrapped phone.
    11-05-2015 11:16 AM
  5. linkiik121's Avatar
    I waiting for the skinomi clear wrap to come in tomorrow will test.
    Posted via Note 5 AT&T
    11-05-2015 11:22 AM
  6. TheLastPanda's Avatar
    I was thinking maybe my carbon wrap has some metallic properties in it that causes interference. Clear wrap probably does not.
    11-05-2015 11:23 AM
  7. me23brown's Avatar
    I've had the same problem and I believe its with the free wireless charger Samsung gives out. I have a thin case on it and it works just fine with the other wireless chargers that I have. The free one is the only one where this happens. It doesn't happen all the time but it does enough for me not to trust using the charger if I'm not going to be looking at it to see if and when it fails.
    11-05-2015 11:30 AM
  8. TheLastPanda's Avatar
    Thanks all. .
    Just want to emphasize that the same wireless charger works perfectly with my coworkers Note 5
    11-05-2015 11:32 AM
  9. me23brown's Avatar
    Yeah I can see that happening too. Mine worked fine for a day or two before it started acting up. I'd wager if your coworker used it consistently for a couple of days it would start acting up on his too. But hey I could be wrong, do you have any other wireless chargers to try yours out on?
    11-05-2015 02:05 PM
  10. maf113's Avatar
    I have the skinomi clear wrap and a Liquid crystal clear case. No problems with charging nor using S-pay.
    11-05-2015 02:10 PM
  11. TheLastPanda's Avatar
    We were switching or phones on and off the same charger back to back and his phone worked every time and my phone never worked properly. The only difference between or phones was that mine is wrapped and his is not.
    I then went to Starbucks because they have wireless chargers built into the tables. My phone charged properly on those chargers.
    I'm guessing that the wrap is causing some sort of interference with the charger so the charger has to work harder to deliver power to my phone. Then the extra current overloads the charger and shuts it off.
    11-05-2015 02:50 PM
  12. me23brown's Avatar
    Well maybe the wrap is giving you the trouble, I don't know. All I know is I have the same symptoms with the Samsung charger and I don't have a wrap but my phone works consistently on other wireless chargers. I take it you don't have a different charger to test it on.
    11-05-2015 02:56 PM
  13. TheLastPanda's Avatar
    I tested on the PowerMats Starbucks have in their tables and it works fine
    11-05-2015 03:35 PM
  14. me23brown's Avatar
    Yeah then I still think its your charger, what's funny to me is that while early this morning my charger was acting up ever since I first responded to this thread its been working fine. It's like it knows I'm talking bad about it. Good luck with yours.
    11-05-2015 03:57 PM
  15. kj11's Avatar
    I've had two Samsung wireless chargers, both are crap. They charge for a few minutes then the blue light just blinks. Nothing on the back of my phone. Maybe the wrap is playing a part, but more likely the chargers are garbage
    11-05-2015 08:26 PM
  16. TheLastPanda's Avatar
    I will remove my wrap this weekend and test.
    11-06-2015 10:53 AM
  17. prolongExistence's Avatar
    I thought I read somewhere that the Starbucks chargers were not qi chargers. If you go to Best Buy, the Samsung rep should have a qi charger on the desk that you can try out. I suspect that you could be right about the wrap interfering. Maybe it is made of some kind of foil or mylar?
    11-07-2015 04:55 AM
  18. anon(26204)'s Avatar
    I work for Best Buy and I have a note 5 with a Speck Case and a Spigen Clear case. When I place my phone on the wireless charger whether at work or at home (the free one from samsung) it does not charge right away. I have move it around until it finally connects. And then if it does start to charge, it stops at like 90% for some reason and the charger blinks blue. Then I have to re-seat the phone again.
    11-07-2015 09:52 AM
  19. BamaMomRollTide's Avatar
    How did you get a free wireless charger? I had to pay $50 for mine at the AT&T store.
    11-07-2015 05:17 PM
  20. BamaMomRollTide's Avatar
    Found the free source! yay...one will be sent!
    I posted the below in another thread, but may help someone here who is having trouble finding the "sweet spot" for placing their covered phone on the wireless charger.....
    I have a Pelican protection cover on my Note 5. I use the Samsung wireless charger ($50 at ATT).
    I have to place my phone "landscape" with the "charger cord" coming out the top of the wireless (can you picture that?)
    More detail: imagine the charger is a clock and the cord is at 12:00. I have to place my phone landscape (home button on right side).
    I have to set the phone down with a slight "thud" down on the charger...centered...and allowing me to see the "solid blue". If I don't do the slight "thud" then only the blue light goes on, but no charging takes place. The "thud" seems to alert the charger or phone in someway because immediately the phone will indicate that charging has started.
    The "thud" is simply dropping the phone onto the charger from about an inch above the charger...I know, weird, but it works.
    Hope this helps.
    11-08-2015 09:37 AM
  21. Gray Area's Avatar
    I have used 2 free Samsung puck wireless chargers with my note 5 with a thick platinum brand case as well as various thinner tpu cases similar to the spigen and they've both performed flawlessly since day 1 (Aug, 21). I have even purchased a few cheap $3 non branded wireless QI pucks that also work flawless despite the thickness of the case with room to spare! I've held my note 5 in mid air approximately 3mm above the chargers with the thick platinum case on it and it was still charging!
    However, I do have Duracell pma chargers that are hit and miss depending on the case thickness. They won't charge with the platinum thick case at all so it seems they don't have as strong a distance clearance as the QI chargers I have.
    Posted via the modest yet efficient Lenovo Tab 2 A8 50f
    DEVICE HISTORY (since they got smart)
    PHONES: Galaxy Nexus, LG viper, Galaxy s3, HTC Evo 4g, Galaxy Note 2, Galaxy s5, LG G-Flex, Galaxy Mega 6.3, Galaxy s6 edge, Galaxy Note 5. TABLETS: Galaxy Note 10.1 gt-n8013, Galaxy tab 3 7.0. Lenovo tab2 A8 50 WATCH: Galaxy gear
    11-08-2015 03:42 PM
  1. Replacement phone, wireless charging not working
    By Vance14 in forum Google Nexus 6
    Last Post: 11-24-2015, 11:53 AM
  2. WiFi issues with tv
    By robert7107 in forum Ask a Question
    Last Post: 11-04-2015, 07:30 PM
  3. How do I use my phone to record my class lecture?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 11-04-2015, 01:06 PM
  4. not enough space in device storagehow do I delete files
    Last Post: 11-04-2015, 12:50 PM
  5. Replies: 0
    Last Post: 11-04-2015, 11:27 AM
