1. JosephB727's Avatar
    After I installed the new software update seem like the bluetooth is low when you turn the volume all the way up I noticed it when I updated my phone to the latest software update.
    11-05-2015 10:23 AM
  2. SpookDroid's Avatar
    I just updated yesterday (T-Mobile) and used it today in the morning commute and no issues. Have you tried different audio players? Maybe it's the app you're using (Spotify, for instance, had a problem with BT volume for a couple of updates a while ago).
    11-05-2015 11:19 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! Also, make sure the volume is turned way up on both the phone and your Bluetooth device.
    SpookDroid likes this.
    11-05-2015 11:43 AM
  4. SpookDroid's Avatar
    Oh, yeah...remember the 'pesky' safety volume feature. After each reboot, if you want to turn the volume all the way up,you have to dismiss the safety warning or it will only go 3/4 of the way.
    B. Diddy likes this.
    11-05-2015 12:04 PM
  1. I lost the side bar on my Note 5, how can I get it back?
    By AC Question in forum Samsung Galaxy Note 5
    Last Post: 04-24-2016, 11:40 AM
  2. Upgrading from NOTE 3....which to choose?
    By eugchen in forum Samsung Galaxy Note 5
    Last Post: 11-08-2015, 09:24 PM
  3. Screen freeze on Samsung Galaxy Note 10.1, how can I fix it?
    By AC Question in forum Samsung Galaxy Note 10.1
    Last Post: 11-05-2015, 12:22 PM
  4. Screen glitching/sensitivity issue
    Last Post: 11-05-2015, 11:57 AM
