04-21-2016 03:05 AM
28 12
tools
  1. yongdeng zhang's Avatar
    Unfortunately, reflashing the firmware didn't work. You are right. The problem is probably caused by the most recent OTA update from Samsung and many people suffers from the same problem now.
    Check here:http://forum.xda-developers.com/note5/help/android-os-battery-drain-stay-awake-idle-t3236660/page4
    The only solution so far is to root the phone and switch to a custom kernel. However, I don't want to do that. Hopefully next OTA update will fix it.
    11-13-2015 11:26 AM
  2. Tushar T's Avatar
    Hi, I have just purchased a new Galaxy Note 5 Duos and even without inserting sim card or witout connecting to Wifi also the battery dropped by 30% in night. I have not installed anything yet, and the battery is draining like crazy. The battery usage shows Android System and Android OS as highest consumers. Did you find any solution to this problem so far? Should I return the phone or it is generic problem?
    Thanks in advance
    01-08-2016 01:25 PM
  3. Jaun-pierre Van Bosch's Avatar
    hello there, I am suffering with the exact same problem with the samsung galaxy NOTE 4 and have also tried some of those thing but they don't work for me aswell..... so pleas tell me if you come up with a solution I am hoping adroid 6.0 wil fix it
    04-21-2016 03:05 AM
28 12
  1. Social Media in the Blackberry Hub
    By Freelance1040 in forum BlackBerry Priv
    Last Post: 11-10-2015, 08:09 AM
  2. how to back my android keyboard
    Last Post: 11-09-2015, 11:55 PM
  3. Replies: 1
    Last Post: 11-09-2015, 11:53 PM
  4. how to back my android keyboard
    Last Post: 11-09-2015, 09:47 PM
  5. Replies: 0
    Last Post: 11-09-2015, 09:31 PM
