So I have had the 64GB Note 5 on Verizon for just over 1 week but not everything is perfect.
I get random network issues where it will completely disconnect from the network and only a restart gets me back on...weird. I thought network performance would be better than my previous note 3 but it is way worse for me.
It's annoying to me that the backup to fingerprint is a alpha/numeric Password only and can't be a different security method like a pin.
Samsung Pay seems to randomly appear on the bottom of the screen when I unlock even though it is turned off.
I seem to have lag issues...debated a reformat. When using Nova, it's bad but even using the default, it's not fluid like I hoped. Little hick-ups here and there....just not a perfect experience for some reason. Coming from a Note 3, I thought the difference would be massive. Every so often I get these lock screen hickups as well.
I still miss my menu button
The good news: Camera is AWESOME and I love pro mode. Battery life is solid but not ground breaking. I don't use the pen often but when I do, it's great. Build quality is definitely improved though I'm worried it's a bit fragile. Overall, it's probably the best device out there if I can figure out my connection issues.
