1. eric0668's Avatar
    I am looking to get an Unlocked Note 5 in Silver (does anyone have this or have you seen it - does it look as good in person)
    My question is: There are many unlocked versions, but I believe there are several versions that may work in the US
    But I am thinking it is one of: N920C or N9200 or N920I (I am thinking it is the N920I, with the "I" standing for International?)
    Can anyone tell me which works on GSM in US, T-Mobile
    Thanks
    11-12-2015 06:39 PM
  2. mrbrock72's Avatar
    Thanks
    Yes it should work. I ordered the same model to use with Cricket. Check this site. willmyphonework dot net
    11-13-2015 01:26 PM
  3. cnotes2019's Avatar
    Which U.S. model if unlocked can work on a different carrier and get lte? (Verizon Att tmobile)
    11-13-2015 05:49 PM
  4. eric0668's Avatar
    I was eventually told today the N920G is the one to get. It can be verified on Best Buy site also. The N9200 or N920i may work, and are international version but not made for US
    I don't believe any will work on VZ. Someone plz correct me if wrong.
    11-13-2015 06:12 PM
  5. Allenhardiman's Avatar
    You are right since VZ uses CDMA network which is different from gsm phones
    11-13-2015 06:14 PM
  6. dpham00's Avatar
    The Verizon one is factory sim unlocked. It will get limited lte on tmobile and especially att.
    11-13-2015 11:22 PM
  7. eric0668's Avatar
    Just get the N920G. I forget if I posted it here or XDA, but that is what Sammy, NewEgg, and Best Buy said is the US version unlocked.
    11-13-2015 11:27 PM
  1. galaxy Note 5 Headphones
    By Izaiah Williams in forum Samsung Galaxy Note 5
    Last Post: 11-13-2015, 09:52 AM
  2. Fingerprint unlock delay
    By nydog in forum Nexus 5X
    Last Post: 11-12-2015, 09:06 PM
  3. Replies: 3
    Last Post: 11-12-2015, 05:31 PM
  4. How much will it cost to repair a broken screen on a Samsung Note tablet?
    By AC Question in forum Samsung Galaxy Note 10.1
    Last Post: 11-12-2015, 04:07 PM
  5. Replies: 0
    Last Post: 11-12-2015, 03:58 PM
