1. cnotes2019's Avatar
    I was just wondering if tmobile note 5 come unlocked and if not can I get it unlocked and will it work on Att lte? Similar question in regards to an Att note 5. Thanks
    11-13-2015 06:13 PM
  2. cnotes2019's Avatar
    Anyone?
    11-13-2015 10:44 PM
  3. dpham00's Avatar
    The att note 5 will get all the lte bands tmobile needs. We won't discuss 4g since you aren't concerned about it.
    The tmobile Note 5 gets most of the lte bands for att,but is missing two secondary bands
    Both are soon locked, but you could get it unlocked
    Features like wfc night not work.
    11-13-2015 11:15 PM
  4. cnotes2019's Avatar
    Say I am concerned with 4g. How does that factor into which model is best to get? And to be clear the Att model supports all T-Mobile lte bands if unlocked? Thanks!
    11-14-2015 06:03 AM
  5. cnotes2019's Avatar
    Doesn't T-Mobile version include lte 1234578 12 and 20 which is what Att uses?
    Oh it's missing 17 and 29
    11-14-2015 10:10 AM
  6. dpham00's Avatar
    The att version doesn't support aws the 4g which tmobile uses...it depends on whether or not your area uses it...
    11-14-2015 02:14 PM
  7. cnotes2019's Avatar
    So the Att version can support it if my area uses it or it doesn't at all no matter what?
    11-14-2015 05:48 PM
  8. dpham00's Avatar
    The att version doesn't support aws 4g. So you will not be able to get aws 4g no matter where you are. TMobile has pcs 4g deployed in certain areas however aws is Tmobile's main 4g deployment.
    11-14-2015 11:49 PM
  9. Crashdamage's Avatar
    Go to this site. It will sort it all out for you. You'll need to know the sub-model number.
    http://www.willmyphonework.net/
    11-15-2015 03:54 AM
  10. cnotes2019's Avatar
    That site says it supports aws
    On a side note, the edge plus says it supports the same things.
    11-15-2015 05:15 AM
  11. cnotes2019's Avatar
    So does it or doesn't it have aws??
    11-15-2015 05:25 PM
  12. cnotes2019's Avatar
    I NEED YOUR help my friends?!?! Itching to buy from AT&T or eBay
    11-15-2015 06:37 PM
  13. dpham00's Avatar
    The att version doesn't support 4g aws. Note that att considers h+ umts to be 4g,but Samsung considers h+ umts to be 3g.
    FREQUENCIES AND DATA TYPE
    Infra: 2G GSM, 3G WCDMA, 4G LTE FDD;
    2G GSM: GSM850, GSM900, DCS1800, PCS1900;
    3G UMTS: B1(2100), B2(1900), B5(850);
    4G FDD LTE: B1(2100), B2(1900), B3(1800), B4(AWS), B5(850), B7(2600), B8(900), B17(700), B20(800), B29(700), B30(2300)
    11-16-2015 04:14 PM
  14. dpham00's Avatar
    Tmobile Note 5
    2G GSM : GSM850, GSM900, DCS1800, PCS1900
    3G UMTS(WCDMA) : B1(2100), B2(1900), B4(AWS), B5(850)
    4G LTE FDD : B1(2100), B2(1900), B3(1800), B4(AWS), B5(850), B7(2600), B8(900), B12(700), B20(800)
    11-16-2015 04:16 PM
  15. cnotes2019's Avatar
    But it's not the same even though Att and Samsung consider aws 3G or 4g? Also is there a difference between b17, b12 and b29? Are they different sections of 700? Thanks for your help !!!
    11-16-2015 05:19 PM
  16. dpham00's Avatar
    Again, att doesn't support h+ aws umts. The tmobile one does. Both att and tmobile support aws lte.
    LTE band 29 is a minor band for att. B17 is a subset of b12 but the Carrier needs to support the specific band for it to work
    Laura Knotek likes this.
    11-16-2015 05:28 PM
  17. cnotes2019's Avatar
    Thanks for your help and patience! I think I'm going to go work the gold tmobile version 32gb as I haven't had a tmobile branded phone in years. It will of course be used on tmobile. I already have an Att note 4 and verizon note 3 so might as well get a tmobile note 5 mostly because of the color. Thanks again!!
    11-16-2015 05:38 PM
  1. S Pen notes to Google Keep?
    By Ticojpunk in forum Samsung Galaxy Note 5
    Last Post: 11-18-2015, 04:27 AM
  2. Replies: 1
    Last Post: 11-13-2015, 11:12 PM
  3. How do I do 3 way calling on the s6?
    Last Post: 11-13-2015, 11:09 PM
  4. New sd card has three folders on it - where do I send my photos?
    Last Post: 11-13-2015, 11:08 PM
  5. Replies: 0
    Last Post: 11-13-2015, 05:21 PM
