07-29-2016 03:53 AM
27 12
tools
  1. amirmasoud ashrafi's Avatar
    Hello everyone.i recently bought Note5 as my second phone and im encountering huge lags while gaming.i always keep my ram free as possible dont even open more than 4*apps*atonce.and*games have really low graphics compared to my other phone 6S Plus.
    Asphalt 8:lags but playable*
    Modern combat 4-5:Huge lag unplayable
    Gta san andreas:hug lag even on lowest settings unplayable
    Dead trigger 1-2:no lag
    Sky force:no lag
    Gangster Vegas:small lag but really bad graphics(on very high)
    Dead effect 2:medium lag
    Mortal kombat x:no lag
    Marvel contest of champions:no lag
    Brothers in arms 2:medium to high lag almost unplayable
    I fell like that my gpu is not working the way it should.
    Is there a fix to this problem???if there isn't ill just buy a Z5.
    Last night i read on XDA that samsung has this thing called fovs(i think)that limits the gpu functionality in order to save battery and keep the phone from over heating.
    My antutu is about 65000.
    If any info about my phone is needed just say and ill answer right away.
    11-17-2015 12:12 PM
  2. mstrblueskys's Avatar
    Sky force:no lag
    Go into your power or screen or energy saver settings and see if there are any options to set it for "Performance" instead of balanced. Try rebooting and only opening that one game and see if that's an issue.
    Also, try a little less intense graphics settings and see if that's the issue. I doubt you'll notice the difference between 2k resolution and 1080P, and that should make a difference!
    11-17-2015 12:28 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! That's good advice. Also, if you have some "RAM booster" installed, try uninstalling it. Those apps can actually cause performance issues, for example if they keep trying to close apps that are automatically opening in RAM. Android wants to keep RAM relatively full, so if you have a RAM booster that's fighting it, it might get into a cycle of app closing-opening-closing-opening, which ultimately uses CPU and battery.
    11-17-2015 12:56 PM
  4. Ryano89's Avatar
    Download an app called game tuner. It will let adjust performance levels for games. It works great. https://play.google.com/store/apps/d...gametuner.thin
    11-17-2015 01:12 PM
  5. amirmasoud ashrafi's Avatar
    There is no battery mode (performance-balanced-... )removed the ram cleaner apps no difference---downloaded game tuner perfomance just got worse.
    11-18-2015 08:44 AM
  6. amirmasoud ashrafi's Avatar
    Even a small game like asphalt nitro has lag compared to 6S Plus.
    11-18-2015 08:54 AM
  7. B. Diddy's Avatar
    Just to make sure it's a genuine Note5 and not a clone/knockoff, install and run CPU-Z to make sure it has the correct processor hardware listed (unless AnTuTu does this as well).
    11-18-2015 10:57 AM
  8. amirmasoud ashrafi's Avatar
    For some reason i cant send pictures android central app stoppes working it has Samsung exynos octa 7420 2.10 GHz.
    11-18-2015 11:57 AM
  9. B. Diddy's Avatar
    Are you able to compare the performance on your Note5 with someone else's Note5? If the problem is exclusive to your unit, contact your wireless store or Samsung for a replacement.
    11-18-2015 12:25 PM
  10. geoffjam78's Avatar
    What about going into DFU mode or whatever it's called, and clear the cache? Not sure if that would help.
    11-18-2015 12:38 PM
  11. amirmasoud ashrafi's Avatar
    First DFU is an ios thing
    Second my device doesn't have warranty
    Third no ond i know has a note5.
    11-18-2015 01:43 PM
  12. racedog's Avatar
    Where did you get this phone that it doesn't have a warranty? I'm wondering if someone didn't sell you a Note 5 knock off.
    11-18-2015 02:26 PM
  13. amirmasoud ashrafi's Avatar
    In iran warranty costs you 100 to 300 dollars.
    11-18-2015 02:57 PM
  14. Matt Behnken's Avatar
    small idea Just to make sure . power saving Mode -ls off from drop down menu ?
    11-18-2015 03:31 PM
  15. amirmasoud ashrafi's Avatar
    Its always off.
    11-18-2015 05:17 PM
  16. Matt Behnken's Avatar
    Its always off.
    there are some Options for CPU GPU underdeveloper mode. Tap build number 8 times In settings/ about
    11-18-2015 05:22 PM
  17. amirmasoud ashrafi's Avatar
    They are set for maximum performance.
    11-18-2015 05:35 PM
  18. Matt Behnken's Avatar
    Do they lag offline also
    11-18-2015 05:40 PM
  19. amirmasoud ashrafi's Avatar
    Yep.
    11-19-2015 01:01 AM
  20. Matt Behnken's Avatar
    i want to try one out. Surely 4 GB of RAM and 8 cores can handle these. Downloading gangster vegas right now :/
    11-19-2015 01:15 AM
  21. Matt Behnken's Avatar
    This is a screen recording from my note 5 so it can be a tiny bit choppy but does this look laggy? It felt smooth in game, but i will try it on ios also.
    https://drive.google.com/file/d/0B3j...p=docslist_api
    This link expires in 24 hours
    11-19-2015 01:57 AM
  22. amirmasoud ashrafi's Avatar
    Mine is just like that.but ios has better graphics and perfomance.also i tried my friends Z5 and its just like ios probably because of ADRENO .
    11-19-2015 04:19 AM
  23. amirmasoud ashrafi's Avatar
    Well just tested a few games on my father's S6 Edge and games were as fast as ios.maybe I should do a factory reset.
    11-19-2015 10:31 AM
  24. Matt Behnken's Avatar
    Man i hope the factory reset fixes it. If not and u have to PAY for warranty i wouldnt pay a damn thing. I would hit up samsung and tell them the problem see if theyll send u a refurb free with fixed gpu
    11-19-2015 01:10 PM
  25. amirmasoud ashrafi's Avatar
    Well i did factory reset and all is working great.
    B. Diddy likes this.
    11-22-2015 02:40 AM
27 12
  1. Problem with function of Apps Launcher page
    By Petros DIMITRIOU in forum Google Nexus 9
    Last Post: 11-18-2015, 02:34 AM
  2. Replies: 1
    Last Post: 11-17-2015, 01:02 PM
  3. How can I fix a noise on the phone?
    By oneactplay2 in forum General Help and How To
    Last Post: 11-17-2015, 12:25 PM
  4. Replies: 1
    Last Post: 11-17-2015, 12:22 PM
