1. leow zhun xiong's Avatar
    I have noticed this over the last few days.
    11-20-2015 01:08 AM
  2. SpookDroid's Avatar
    What do you mean by 'fast charging problem' exactly? If you're using a different cable, that might be the problem. I've used mine with a longer cable and I have to plug it in and out a couple times for it to recognize the Fast Charging (otherwise it just uses 'normal' charging), but if I used the supplied cable, I have no issues.
    11-20-2015 01:58 AM
  1. Note 5 - Issue with Fingerprint Scanner
    By 123Easy in forum Samsung Galaxy Note 5
    Last Post: 12-05-2015, 06:10 PM
  2. Youtube problems still!
    By MsSparkie in forum Android 5.0 Lollipop
    Last Post: 11-22-2015, 03:59 PM
  3. No longer fast charging
    By BellaGee in forum Samsung Galaxy Note 5
    Last Post: 11-22-2015, 02:33 AM
  4. Replies: 0
    Last Post: 11-20-2015, 12:52 AM
  5. How can I fix a reset problem?
    Last Post: 11-19-2015, 10:30 PM
