01-29-2016 01:35 PM
104 12345
tools
  1. recDNA's Avatar
    Anybody with vzw version got this problem?
    12-28-2015 10:19 AM
  2. Philipmom's Avatar
    I have Verizon and mine just started doing this also. Wiped my cache and it seems fine for now.
    12-28-2015 01:48 PM
  3. TrevolutionNow's Avatar
    My first Note 5 was awesome until I broke the glass over the rear camera. The replacement I received began having the dead spot issue about a week after i received it. My new replacement (my 3rd Note 5) immediately showed the same issue. Not sure what to do.
    12-28-2015 10:51 PM
  4. TrevolutionNow's Avatar
    After deleting Facebook Messenger the problem immediately went away. I'll post if it returns.
    12-28-2015 11:00 PM
  5. Steve Allman's Avatar
    Same problem here. 1 year old note4. Doesn't have samsung pay. Just started doing it a week or so ago. Verizon
    12-30-2015 06:56 AM
  6. Javier P's Avatar
    The problem seems related to the Messenger bubble heads. Disable them and see if the problem persists.
    tkpc621 likes this.
    12-30-2015 07:08 AM
  7. Philipmom's Avatar
    I've cleared my cache and have been using messenger bubbles. Issues have not returned for a few days now. VZW note 5.
    Javier P likes this.
    12-30-2015 07:21 AM
  8. Javier P's Avatar
    That's good to know! Which cache did you clear? Partition wipe from recovery or just apps cache from settings - storage?
    12-30-2015 07:29 AM
  9. Philipmom's Avatar
    I did a full partition wipe.
    12-30-2015 09:58 AM
  10. Philipmom's Avatar
    Well poo. The corner came back. Removed Facebook messenger and it immediately worked.
    12-30-2015 04:19 PM
  11. sp44's Avatar
    Isn't there a dialer number to get into internal settings like the screen? I did one with a S6 and it fixed my screen responsiveness.
    01-01-2016 08:11 PM
  12. Hamsterstyle1's Avatar
    Hey guys, new phone same problem. Phone number 6, problem returned in an hour. Only thing that works is Droid Optimizer, stop Background Apps. The problem comes back but you can fix it with the app without having to reboot phone. Again, I've run the phone barebones and it comes back. I don't know which app it's clearing to make the screen responsive again, but it does work everytime. But I do have to do it from once a day to 5 times. Good luck. Besides this the phone runs like a dream. Also I deleted Nova because it eats too much RAM.
    01-02-2016 02:09 AM
  13. Hamsterstyle1's Avatar
    *#0*# in the phone dialer.
    01-02-2016 02:12 AM
  14. benleonheart's Avatar
    Nexus6 here, no problems at all.
    01-02-2016 10:29 PM
  15. benleonheart's Avatar
    Nova never eats as much ram as Touchwiz would eat by itself.
    01-02-2016 10:30 PM
  16. Bttyboop424's Avatar
    I just had my phone replaced and read that fb messenger could be the biggest problem.. Deleted the app and problem solved
    01-02-2016 10:34 PM
  17. Hamsterstyle1's Avatar
    I would show you the screen caps but I'm too tired. With just touchwiz, 1.5 gig free RAM, with Nova, 890mb free.
    01-02-2016 10:55 PM
  18. Hamsterstyle1's Avatar
    This problem involves galaxy note 5 mostly. Please read the thread before mocking our problems.
    01-02-2016 10:57 PM
  19. benleonheart's Avatar
    Hmm... I'm actually commenting on this thread because someone with a Nexus6 said to have had the same problem.
    Just go ahead and clear the cache partition from recovery, you guys'll be ok.
    01-04-2016 03:02 PM
  20. Hamsterstyle1's Avatar
    LOL ok you're Trolling. When I say everyone has tried all options I mean....
    01-06-2016 12:17 AM
  21. Tarka22's Avatar
    I use Nova, always have and I am experiencing the same Upper Left Corner Issue! I have been trying to pay attention and track when it works vs not, to find the CULPRIT, whether it be a Third-Party App, a Software malfunction, Mechanical Issue OR if simply my 'Finger Taps' are just too much to handle! 😎
    I purposefully will work solely from one App, closing all others, (that I am able & aware of anyway) and it hasn't made a difference.
    *I did read on another Forum that Messenger was the cause. They said they Uninstalled it and it seems to be working. Has anyone else tried that? Or any other removals that seem successful??
    Thanks,
    Tarka
    01-06-2016 01:16 AM
  22. cane929's Avatar
    Any other update on this issue? I am trying to decide if I should switch to the Note 5 from iphone 5, Thanks.
    01-06-2016 08:47 AM
  23. drewood31601's Avatar
    The issue has been detected and the only viable work around has been to disable the Facebook messenger app. Facebook has not updated the app as I'm typing this. Once the messenger app is updated (current date is Dec 14th) then I would recommend you reinstalling and see if the problem returns.
    01-06-2016 09:59 AM
  24. Javier P's Avatar
    For some people just disabling the chat heads in Facebook Messenger fixed the problem. Worth a try.
    01-06-2016 10:18 AM
  25. drewood31601's Avatar
    Is that what you did? I never had chat heads enabled on my N5 and so I don't believe it was the problem for me. I did try using it with chat heads working a few days ago and the problem was there. The only thing that has worked for me has been to disable the messenger app..which I actually liked a lot, and I do check every day to see if they have updated it. (Messenger app)
    01-06-2016 10:38 AM
104 12345
  1. Replies: 3
    Last Post: 07-10-2016, 01:07 AM
  2. Lock Screen Notifications
    By fukengruven in forum Samsung Galaxy S6 edge
    Last Post: 12-13-2015, 08:03 AM
  3. Replies: 4
    Last Post: 12-12-2015, 03:46 PM
  4. What is this update that has come through to my Note 4 does anyone know?
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 12-12-2015, 12:16 AM
  5. The clock and weather on my home screen disapeared.
    Last Post: 12-11-2015, 02:08 PM
