1. Bluering's Avatar
    The thin USB cable that comes in the box with the Note 5 seems to be of a poor quality. If I plug it to my new Samsung fast wireless charger, it does not charge properly. I have another two cables the thick ones and one is from my ex-S5, and those cables work without any problem. Talked to a Samsung person on chat line explaining the issue, I can’t believe, I was told I must take the phone and the cable to their technician which is a bit far away from my place. I explained that the two other cables are working well and it is only that thin cable which is causing problem and it is only one week old, but no avail.
    11-23-2015 06:52 AM
  2. bassplayrguy's Avatar
    I have 3 of the Samsung cables for the Note 5 and 2 generic ones. No problem fast charging at all.
    linkiik121 likes this.
    11-23-2015 07:17 AM
  3. TV417's Avatar
    I agree with you. I was having problems with the fact charging, and soon as I changed to my old cable, it works fine.
    Bluering likes this.
    11-23-2015 08:50 AM
  4. Bluering's Avatar
    3 cables? Are you talking about the thin one that comes in the box? Well the phone comes with only one cable in the box, you can't have three cables out of the box.
    11-23-2015 07:22 PM
  5. Soylent_Green's Avatar
    Seems fine to me just don't abuse it.
    11-23-2015 08:14 PM
  6. TTQ225's Avatar
    How can you tell if it's fast charging beside clocking the charge time? Any indication on the screen?
    11-24-2015 11:34 AM
  7. Darth Mo's Avatar
    When you plug in the phone the status bar will show "Charger Connected" initially and will scroll to say "Fast Charging" immediately after.
    11-24-2015 12:02 PM
  8. bassplayrguy's Avatar
    I have the one from the box the phone came in and I have purchased 2 wireless chargers that come with the same cable as the phone, so yes it is possible that I have 3 cables out of the box. None of which have any issues charging.
    11-24-2015 01:12 PM
  1. Replies: 1
    Last Post: 11-23-2015, 11:19 PM
  2. Note 4 5.1.1 always awake - never sleeps
    By Buzz20 in forum Android 5.0 Lollipop
    Last Post: 11-23-2015, 11:03 PM
  3. Note 5 sim error one day may be 50 above times restart phone?
    By AC Question in forum Samsung Galaxy Note 5
    Last Post: 11-23-2015, 11:02 PM
  4. Locked out of my Note 5, how can I get in?
    Last Post: 11-23-2015, 07:09 AM
  5. Charging for Note 4, can I use generic chargers?
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 11-23-2015, 02:47 AM
