1. AC Question's Avatar
    solid blue light on and phone beeping every few minutes. Black screen.
    Any way to fix that?
    11-23-2015 04:26 PM
  2. AlphaTango414's Avatar
    If I'm understanding your situation right, sounds like you are in a wake lock.
    If that is the case, then two things to try. First hold volume down and power button for 10-15 seconds to force a simulated battery pull. Also if that doesn't work, try plugging your phone into your PC.
    Hope one of these works for you. I'd suggest wiping system cache via the recovery menu.
    11-23-2015 05:25 PM
  3. Brinder Panesar's Avatar
    Tried both methods and nothing.
    I think i dropped it and must have screwed something up.
    11-23-2015 06:15 PM
  4. pennywood52's Avatar
    Did you find anything out about your phone I dropped mine and it's doing the same thing
    10-16-2016 08:00 AM
  1. Galaxy Note 5 does not have a conference call feature?
    By AC Question in forum Samsung Galaxy Note 5
    Last Post: 04-18-2016, 08:36 AM
  2. Notification sound issues on Samsung S6 64gb, can I get some help?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 11-24-2015, 01:35 PM
  3. Why is my emoji keyboard making keypress sounds on Galaxy Note 5?
    Last Post: 11-23-2015, 09:46 PM
  4. Samsung Qi Wireless Charger, how can I fix it?
    By Dannyr05 in forum Samsung Galaxy S6
    Last Post: 11-23-2015, 04:10 PM
  5. Why is my Samsung Qi Wireless Charger blinking green?
    Last Post: 11-23-2015, 03:22 PM
