1. AC Question's Avatar
    I have galaxy note 5 from verizon. Whenever I am connected to a wifi by battery drains from standby usage. I did research and it seems like a wifi bug because my 4g is still on even when I am connected to wifi. When I am not connected to wifi it is fine but I can't afford to not use wifi.
    I tried to clear cache, tried a different wifi, package disabler, altering advanced call feature but nothing worked.
    Anyone know if there's a fix for this?
    11-29-2015 09:52 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Is it Cell Standby that's showing up in the battery stats?
    11-30-2015 12:51 PM
  3. bseo0406's Avatar
    Yes it is! is there a fix for this?
    11-30-2015 08:00 PM
  4. B. Diddy's Avatar
    Is the cell signal strong when this happens, or is it pretty weak?
    12-01-2015 12:23 AM
  5. Trees's Avatar
    As B. Diddy suggests, if cell signal is strong, then the thread below may help.
    http://forums.androidcentral.com/sam...g-verizon.html
    B. Diddy likes this.
    12-01-2015 06:38 AM
  6. Ryano89's Avatar
    I'm on Verizon, and I have NO idea why this worked, but switching data from global to LTE/CDMA only seems to have fixed my cell standby draining while on WiFi.
    12-01-2015 01:39 PM
  7. dswatson83's Avatar
    I have to disable wifi or I have issues. Also, it seems that the Note 5 doesn't really work with CDMA very well (if at all) and now you need voice over LTE to have internet while on a phone. I feel like the phone is always trying for LTE networks now vs with other phones it would settle on 3g networks when LTE was not around.
    12-01-2015 02:59 PM
  1. AFT does not work with Note 5
    By ipaulr in forum Samsung Galaxy Note 5
    Last Post: 08-27-2016, 10:30 PM
  2. How can I get my Note 3 to connect to 802.11ac wifi?
    By AC Question in forum Samsung Galaxy Note 3
    Last Post: 11-30-2015, 12:59 PM
  3. Verizon Galaxy 10.1 Note conversion from Verizon system?
    By AC Question in forum Samsung Galaxy Note 10.1
    Last Post: 11-30-2015, 12:57 PM
  4. Battery life problem battery draining fast
    By Mm.muhammad.abdulllah in forum Ask a Question
    Last Post: 11-30-2015, 12:23 AM
  5. My battery doesn't keep its charged, why?
    By AC Question in forum Batteries
    Last Post: 11-29-2015, 08:17 PM
