1. AC Question's Avatar
    I don't have wifi at home.
    I have a Galaxy Note 5 with T Mobile, with unlimited data.
    I have a new Samsung Smart TV (Samsung J5200 Series).
    I'd like to stream movies from my Note 5 to my TV without wifi.
    I tried the Samsung Micro USB to HDMI Adapter (MHL), but it didn't work.
    Is there any other way?
    Many thanks!!
    11-29-2015 11:43 PM
  2. outgamed100's Avatar
    I believe micro usb to hdmi is the only other option but as you stated that doesnt work so you might just be out of luck
    Posted via my Samsung galaxy S5
    11-30-2015 03:41 AM
  3. wookiee2cu's Avatar
    Not sure if it requires wifi or not but on the Samsung TV change the source to Screen Mirror, then on the phone swipe down and if you don't see Screen Mirroring icon then click on edit so you see more icons (don't click on the gear icon). Press on Screen Mirroring and it should locate your TV and then select it... this is if it does not require wifi. If this does require wifi then the 4th post in this thread said they used the Amazon Fire Stick as it doesn't require wifi to mirror http://forums.androidcentral.com/sam...-can-i-do.html .
    11-30-2015 05:52 PM
  1. Need to reinstall stock firmware, how can I do this?
    By androidnewb1123 in forum Software Development and Hacking
    Last Post: 12-16-2015, 06:37 PM
  2. How do I cool down my S6 Edge so it can charge?
    By AC Question in forum Samsung Galaxy S6 edge
    Last Post: 11-30-2015, 03:48 AM
  3. Replies: 1
    Last Post: 11-30-2015, 03:43 AM
  4. Why are my sent text messages appearing back to myself?
    Last Post: 11-29-2015, 11:14 PM
  5. does my lg stylo support usb host mode
    Last Post: 11-29-2015, 10:36 PM
