1. khan_1212's Avatar
    I have the note Note 5 on AT&T and I am using it in the UK on Three network. I need to update the software to the latest baseband LMY47X.N920AUCU1AOJ1. I was wondering if anyone knows how to or if someone could get me a download link from they phone so i could install it manually.
    12-08-2015 11:17 AM
  2. SpookDroid's Avatar
    Have you tried using Kies to see if there is an update? Unfortunately AT&T is notorious for locking down their updates to having one of their SIM cards or the phone won't 'see' the update
    12-08-2015 12:07 PM
  3. khan_1212's Avatar
    I have tried Kies but according to Kies its up to date, but i know it ain't.
    12-08-2015 12:12 PM
  4. SpookDroid's Avatar
    Yeah, that's AT&T's lockdown most likely. If you know anyone with an AT&T SIM or plan on coming to the US soon, that's one way to go. Or hopefully someone can chime in with the links, although if they're not coming directly from the AT&T page or a site that has AT&T permission to host the files, chances are our mods will have to remove said link (while tinkering with Android is a cool thing, posting unofficial copies of someone else's property can be considered piracy, even if the app/ROM is free).
    12-08-2015 12:22 PM
  5. khan_1212's Avatar
    ok thanks for that info. the reason i needed the software update was cuz i just got the new GEAR VR and i need the update to support my phone. do you know a way for me to get the oculus app?
    12-08-2015 01:08 PM
  6. SpookDroid's Avatar
    I'm sure the APK is floating around somewhere, too... Again, we can't post the links for APKs and it's not guaranteed that it'll work in your phone, but you can try it. Worst case scenario it will not run.
    12-08-2015 01:30 PM
  7. khan_1212's Avatar
    I managed to get the oculus app on my phone, but when I open it I can't login as a error message shows "An Error Occurred, Please try again. Is they any way I could bypass the login?
    12-09-2015 09:51 AM
  8. SpookDroid's Avatar
    Not that I know of. That, definitely, would fall under the 'hackery' category...
    12-09-2015 12:22 PM
  9. Wim Wouters's Avatar
    Have you found a fix? I'm dealing with the same problem here in Belgium...
    12-16-2015 06:17 AM
  10. md01asif's Avatar
    My note5(64GB) Build number is LMY47X.N920AUCU1AOGG. Please give me the link for stock Rom Android 5.1.1 and again please give me the update rom for my galaxy note5(N920A)N920AUCU1AOGG.
    Thanks
    03-02-2016 08:21 PM
  1. 6.0.1 update waiting room
    By bhatech in forum HTC One A9
    Last Post: 01-15-2016, 10:43 AM
  2. Unlocked Priv on at&t VoLTE
    By rickms80 in forum BlackBerry Priv
    Last Post: 01-06-2016, 11:46 AM
  3. AT&T HTC A9 now getting a system update
    By snowboarders in forum HTC One A9
    Last Post: 12-15-2015, 10:40 AM
  4. Can't watch videos on Note 5 while on a call
    By Ro40 in forum Ask a Question
    Last Post: 12-08-2015, 12:45 PM
  5. Replies: 2
    Last Post: 12-08-2015, 12:23 PM
