1. jrisch's Avatar
    I've had my Note 5 now for a couple of weeks, replacing my aged Note 3. I love the Note 5 and it is a great upgrade. The lack of a removable battery doesn't impact me at all, I prefer to use a separate power pack for the very occasional times an additional charge is needed. The lack of microSD card slot is a minor irritant, but I got the 64GB Note 5 and I carry SanDisk Ultra Dual for the videos I want to have available.
    There are a few issues/irritations going from the Note 3 to the Note 5:
    • Despite the higher density, a folder on the Note 5 only displays 9 visible items, whereas the lower density Note 3 can display 16.
    • The contact widget is missing a direct dial version. I have found a Shortcut Dial Pro app but the widgets it creates have very small images.
    • The button arrangement with multitasking on the left is taking some getting used to. I still find myself long-pressing the home button.
    • I miss the Pen Window from the Air Command (yes, I am an S-Pen user). Just to draw a quick rectangle and pop a calculator in it was so easy.
    • I have the S-Pen Removal set to trigger Action Memo, and both devices are in S-View cases. On the Note 3 I can write straight onto the window without opening the case. On the Note 5 I have to open the case first which wakens the device, then put it back to sleep with the power button, before withdrawing the pen to black screen write.
    • Have to scroll through the home screens whereas the Note 3 allows you to switch by tapping the appropriate home screen button.
    • And the app drawer has to be sorted manually!
    They are small irritations in themselves and I really love the Note 5. Any suggestions for overcoming these are welcome, and any thoughts on further irritations I've yet to find?
    12-15-2015 06:55 AM
  2. dpham00's Avatar
    I use Nova which let's me make much larger folders and sorts app drawer automatically.
    12-15-2015 09:18 AM
  3. russel5150's Avatar
    I miss the direct dial, they should have kept it.
    Sent with my white Note5 with nonremovable back and no SDcard!
    12-16-2015 03:49 AM
  4. Trees's Avatar
    Tapping the home screen buttons work in TouchWiz for automatically scrolling through the various home pages.
    12-16-2015 06:25 AM
  5. jrisch's Avatar
    Tapping the home screen buttons on the Note 5 scrolls one screen at a time, same as if you swipe. On the Note 3 tapping the 4th button, say, jumps to the 4th home screen no matter which home screen you were on. It's a small thing, but if I have the last screen dedicated to a calendar, it's swifter to just tap the last button rather than scroll across.
    Trees likes this.
    12-16-2015 05:14 PM
  6. jrisch's Avatar
    As I noted, the Shortcut Dial app generates direct dial widgets. I just don't like the images it shows.
    12-16-2015 05:16 PM
  7. jrisch's Avatar
    I've never used another launcher other than the Google Now launcher on my Nexus 7, but on my 4th TouchWiz device I'm finally considering switching.
    12-16-2015 05:21 PM
  8. srinathp1988's Avatar
    I noticed that in the default launcher, calendar and clock shows the correct date and time in home screen icon itself like iphone but when i use nova launcher, it just shows some static date in calendar widget. Any idea how to fix this?
    12-16-2015 07:54 PM
  9. jrisch's Avatar
    My N920C has just updated to Marshmallow and the direct dial widgets are back, as is the capability to jump to a specific window in both the app drawer and the home screen by tapping the mini buttons.
    03-17-2016 06:48 AM
  1. Replies: 65
    Last Post: 06-29-2016, 02:17 PM
  2. Touchscreen Issues
    By LinuxWeather in forum Pixel C
    Last Post: 12-29-2015, 10:02 AM
  3. Need Help With My First Android Device From An Experienced User
    By AC Question in forum BlackBerry Priv
    Last Post: 12-16-2015, 01:21 PM
  4. Nexus 6 CM13 no more push notification from any email apps
    Last Post: 12-15-2015, 01:45 PM
  5. Need Help With My First Android Device From An Experienced User!
    By J_K_Resnick in forum General Help and How To
    Last Post: 12-15-2015, 05:31 AM
