12-21-2015 09:36 AM
32 12
tools
  1. bassplayrguy's Avatar
    This is why they should have never taken away the removable battery.
    Would it not deplete a removable battery? I don't follow your logic.
    12-17-2015 09:23 AM
  2. burwil's Avatar
    Your Google Services is off the charts. There is your problem.....
    I recommend you do this....Settings/Device/Applications/Applications Manager/All/Google Play services/Clear Cache
    According to Gsam this is also syncing your google contacts. You need to poke around Google play and contacts and see what might be up. Factory reset is the only other option that I can see. Perhaps others might have some ideas on the Google Services glitch you have....or you can google that. But that's your problem IMO.
    12-17-2015 09:31 AM
  3. LegalAmerican's Avatar
    Yes it would, my guess is he is saying with a removable battery you could just replace it with a new one and be at 100% in seconds.
    12-17-2015 01:50 PM
  4. bassplayrguy's Avatar
    Unfortunately that would not fix the problem. Kind of a nill point on the removable battery.
    12-19-2015 10:20 AM
  5. jsushi's Avatar
    Lol google play services probably sending so much data to their servers....you have to switch some permissions off
    12-21-2015 02:44 AM
  6. burwil's Avatar
    Start removing apps one at a time you really don't need. And see if that puts a dent in drain. Rogue apps can be a problem like that some time. One other shot in the dark, I recall one time I had music stored in two different places. They were mirrors of each other. Can't remember how I did that but it could have been using the Sync app and then re-downloading. Anyway erasing the contents of one location fixed the problem.
    12-21-2015 07:30 AM
  7. LegalAmerican's Avatar
    Putting in a fresh battery would at the very least, instantly give him a few more hours. Although it is simply a band aid and not a cure for the actual problem, it's a heck of a lot better than no more hours on a non-removable dead battery.
    12-21-2015 09:36 AM
32 12
  1. Wireless chargers for the Priv
    By Puzzlegal in forum BlackBerry Priv
    Last Post: 04-14-2016, 02:41 AM
  2. Reboot Loop Only want the pictures
    By bobrobs509 in forum Verizon Samsung Galaxy S4
    Last Post: 12-16-2015, 02:08 PM
  3. How do I wipe clean my Droid Turbo before I send it back?
    By AC Question in forum Motorola Droid Turbo
    Last Post: 12-16-2015, 01:38 PM
  4. Replies: 1
    Last Post: 12-16-2015, 01:36 PM
  5. Galaxy Note 10.1 (Gt-N8013) "S pen has been removed"
    By Dimmu915Borgir in forum Samsung Galaxy Note 10.1
    Last Post: 12-16-2015, 01:29 PM
