12-21-2015 09:36 AM
32 12
tools
  1. Laserbutt's Avatar
    My VZ note 5 never makes it through the night if the battery is around 50% or below. Its driving me crazy. Could it have anything to do with Nova?
    Please Help!
    12-16-2015 06:22 AM
  2. Trees's Avatar
    What does Battery usage show? It may reveal an app(s) running, or if cell signal is poor, the radio consuming power.
    12-16-2015 06:30 AM
  3. Laserbutt's Avatar
    It's shouldn't be cell signal, my wife has an one M8 and it makes it through the night no problem.
    Attached Thumbnails Note 5 - Battery won't make it through the night-2300.jpg
    12-16-2015 06:46 AM
  4. Trees's Avatar
    There's a lot going on for a phone that is not in use. Cell standby at 17%, may mean that its searching for signal. Clicking on the Cell standby icon should reveal more info and show if there is some time without signal. What is also interesting is the Screen at 11%. Is there an app that lights up or wakes the screen frequently while the phone is not being used?
    12-16-2015 06:53 AM
  5. Delirious D's Avatar
    Thats definitely odd. Try connecting it to wifi overnight and see if thay improves. Note 5 - Battery won't make it through the night-uploadfromtaptalk1450272057653.jpg
    12-16-2015 07:21 AM
  6. Laserbutt's Avatar
    Attached Thumbnails Note 5 - Battery won't make it through the night-2307.jpg
    12-16-2015 07:40 AM
  7. Laserbutt's Avatar
    Standby
    Attached Thumbnails Note 5 - Battery won't make it through the night-2303.jpg
    12-16-2015 07:42 AM
  8. Laserbutt's Avatar
    Thats definitely odd. Try connecting it to wifi overnight and see if thay improves. Click image for larger version.
    Would you mind scroll capturing the whole report? Using the screen write function
    12-16-2015 07:44 AM
  9. Delirious D's Avatar
    Note 5 - Battery won't make it through the night-uploadfromtaptalk1450274615804.jpg
    12-16-2015 08:03 AM
  10. Laserbutt's Avatar
    Thank you!
    It seems your stand by and Android system ratios are substantially lower than mine. What am I doing wrong? Do I have a defective device. I'm leaning more on the probability of user error
    Delirious D likes this.
    12-16-2015 08:17 AM
  11. russel5150's Avatar
    Thank you!
    My vz note5 shows the same high usage. I have read that verizon note 5's have the poorest standby. I noticed also that facebook and messenger will show up higher than other things, and i dont use them that much. I got rid of messenger and that helped me.
    I am in an area w really good signal, my turbo 2 and my first turbo dont drain as fast, neither did my note 4.
    I still think it has something to do w having verizons advanced calling setup.
    Sent with my white Note5 with nonremovable back and no SDcard!
    12-16-2015 08:50 AM
  12. burwil's Avatar
    DL Gsam. There you will be able to measure the strength of the cell signal and a more detailed list of app usage. Also might want to consider DLing and installing Doze.
    Laserbutt likes this.
    12-16-2015 08:56 AM
  13. Laserbutt's Avatar
    What should I be looking for?
    12-16-2015 01:36 PM
  14. burwil's Avatar
    Gsam has a graph that shows signal strength. It's the first icon at the bottom left of the screen and then you choose the phone signal tab. You are not losing signal but low signal strength can help tap your battery. Also you can go to settings/about device/status/sim card status and look at the signal strength. Anything over -100 dbms (triple digits) ain't gonna be helpful. Finally look at the main screen of Gsam and look at 'held awake'. I'm at 2%. If something is tapping your battery it's keeping your phone awake. Doze will shut background apps down while the phone is not in use.
    Laura Knotek likes this.
    12-16-2015 01:54 PM
  15. dpham00's Avatar
    Try using wakelock Detector.
    12-16-2015 04:11 PM
  16. hub1's Avatar
    I just charge my phone over night so I can start the day with a full battery. I've done this with every phone I've had and never had any battery problems.
    Maggie45 likes this.
    12-16-2015 04:53 PM
  17. calicocat2010's Avatar
    BUT ONLY IF Rooted.
    12-16-2015 05:53 PM
  18. Laserbutt's Avatar
    Does this suggest anything?
    Attached Thumbnails Note 5 - Battery won't make it through the night-2312.jpg
    12-16-2015 08:08 PM
  19. burwil's Avatar
    This is what mine looks like. My dbms sit at -100. Do you move around alot. Your phone signal fluctuates quite a bit.
    Post this screen...
    Your phone looks like it's discharging very rapidly....might need to take it to your carrier's local store.
    12-16-2015 08:42 PM
  20. dpham00's Avatar
    BUT ONLY IF Rooted.
    Root isn't needed, but you would need adb without root
    http://forums.androidcentral.com/sam...-required.html
    12-16-2015 11:53 PM
  21. jsushi's Avatar
    Hey, it's clearly an app issue. The 63% of app usage is through the roof. Check which apps are draining the battery the fastest. Disable/uninstall them and check again about battery usage. Trust me I've been through this
    12-17-2015 12:18 AM
  22. Laserbutt's Avatar
    https://uploads.tapatalk-cdn.com/201...1d66b77bab.jpg
    Post this screen...
    https://uploads.tapatalk-cdn.com/201...71dde54260.jpg
    Had my phone on the charger all night, I'll let it discharge and post later this morning.
    Attached Thumbnails Note 5 - Battery won't make it through the night-2313.jpg
    12-17-2015 05:48 AM
  23. burwil's Avatar
    Ha! That's me and I'm not complaining. I just asked the OP to post that screenshot. I have mine on a wireless charger so I don't worry about drain and since I've purchased the phone I've been DLing and uninstalling apps. At some point I'll get to a stage where I won't be so active and clear out all the riff raff. BTW you gotta be careful about interpreting the percentages....they all got to add to 100% and some numbers may look big but mean nothing. Like right now I'm at 71% app usage but I'm only draining at 3.5% per hour.Which will take me past one full day on a single charge.
    12-17-2015 07:28 AM
  24. Laserbutt's Avatar
    3.5%??? I'm discharging more than twice as fast, I really don't understand
    Attached Thumbnails Note 5 - Battery won't make it through the night-2315.jpg
    12-17-2015 09:14 AM
  25. Laserbutt's Avatar
    79% app usage breaks down like this
    Attached Thumbnails Note 5 - Battery won't make it through the night-2316.jpg
    12-17-2015 09:15 AM
32 12
  1. Wireless chargers for the Priv
    By Puzzlegal in forum BlackBerry Priv
    Last Post: 04-14-2016, 02:41 AM
  2. Reboot Loop Only want the pictures
    By bobrobs509 in forum Verizon Samsung Galaxy S4
    Last Post: 12-16-2015, 02:08 PM
  3. How do I wipe clean my Droid Turbo before I send it back?
    By AC Question in forum Motorola Droid Turbo
    Last Post: 12-16-2015, 01:38 PM
  4. Replies: 1
    Last Post: 12-16-2015, 01:36 PM
  5. Galaxy Note 10.1 (Gt-N8013) "S pen has been removed"
    By Dimmu915Borgir in forum Samsung Galaxy Note 10.1
    Last Post: 12-16-2015, 01:29 PM
