1. colsnative's Avatar
    Hi all,
    I've been reading and researching on which carrier's Note 5 to get and I could really use some guidance. I read the other night that AT&T's Note 5 has a spyware type program called Carrier IQ so I'm backing away from that version (I had planned to get AT&T's Note 5 and use it on Cricket). Verizon's Note 5 also works on T-Mobile but with no 4G data. Verizon has great coverage but their monthly service plan is expensive, and I am concern their phone is locked down to such a degree that it becomes useless on other carrier's network. I like versatility.
    My initial plan was to get T-Mobile's version for the unlocked bootloader that gives the user more control over what programs to delete, but now I read where some on this forum say the International version is better?
    I'm undecided and hope the more knowledgeable members here can point me in the right direction.
    12-16-2015 07:18 PM
  2. Trees's Avatar
    If I was in your situation, I'd go with T-Mobile if they have good coverage in your area or places you visit.
    12-17-2015 06:35 AM
  3. Brent Michael's Avatar
    Hi all,
    I'd probably get the International version. A lot less bloatware I'd imagine. But do know if you're going with a carrier variant I'd buy the package disabler for like $1.95. It allows you to disable any package or app on the phone no matter what it is, though disable the wrong things you'll have to factory reset the phone to get it to work properly again. And on the matter of malware, no matter what variant you get once you start downloading apps you'll technically have some sort of malware or Spyware.. Just kinda forced to..
    Samsung galaxy note 5 32GB
    Running 5.1.1
    On AT&T
    12-17-2015 11:51 AM
  1. How do I change the voice to keyboard on my ZTE phone?
    By AC Question in forum Other ZTE Android Phones
    Last Post: 08-24-2016, 05:08 AM
  2. I returned my v10 for a note 5 because of battery life
    By Scribble1531AZ in forum Phone Wars
    Last Post: 12-18-2015, 07:15 AM
  3. Replies: 3
    Last Post: 12-18-2015, 12:44 AM
  4. iOS Switch to Android Questions
    Last Post: 12-16-2015, 09:37 PM
  5. How do I find out what AT&T updated on my Zenfone 2E?
    By Traijan in forum ASUS ZenFone 2
    Last Post: 12-16-2015, 06:44 PM
