1. Adel Fakhry's Avatar
    Sudden power drain on my note 5 (first time now) and when i plug the charger it goes back up to 30 from 0 in no time? This is extremely frustrating.
    Attached Thumbnails From 30 to 0 percent in less than 10 mins-screenshot_2015-12-17-05-31-28.jpg
    12-16-2015 09:32 PM
  2. Golfdriver97's Avatar
    Have you tried a reboot? It could be just a temporary bad battery reporting by the OS.
    Laura Knotek and DCounts like this.
    12-16-2015 09:42 PM
  3. Adel Fakhry's Avatar
    Already did that, and i deleted the cache partition as well. I charged it to 100 percent and will continue using it for the rest od the day to see if the issue is still presistent. I will be taking screen shots every 10% drop in power, to monitor how much it takes the battery to drain before reaching 26% (at exactly 26% it drops instantly).
    12-17-2015 03:34 AM
  4. Philipmom's Avatar
    I'd suggest a factory reset or a battery recalibration tool from the play store. If that doesn't work I'd definitely take it in or request a replacement
    Geezer Squid likes this.
    12-17-2015 05:51 AM
  5. clevin's Avatar
    you need to re-calibrate it. Charge it to 90+%, use it until it reaches to 10%, charge up again.
    12-17-2015 06:20 AM
  6. Adel Fakhry's Avatar
    Do i need to have my phone rooted for that? My phone isnt rooted, and what app do you suggest?
    Thanks
    12-17-2015 08:39 AM
  7. Adel Fakhry's Avatar
    Do i need to have my phone rooted for that? My phone isnt rooted, and what app do you suggest to re-caliberate?
    Thanks
    12-17-2015 08:40 AM
  8. Philipmom's Avatar
    I stand corrected. You do need root for the apps because it erases a file. I'd do what a previous poster suggested. Charge and use to 10%. That or factory restore it.
    12-17-2015 10:10 AM
  9. Adel Fakhry's Avatar
    Already charged it to 100% and been using my note 5 heavily since then. From my point of view, I can conclude that there is nothing wrong with the battery, because honestly it has outdone itself 6+ hours of screen ontime chatting checking facebook and video playing (480p quality on mx. That was till it got to 23 % this time and started dropping insanely). There is definitely something wrong with the software not recognizing accurately how much juice left till it is too late. I am currently charging it up again, but I dont want to waste any more time testing it. So should I just leave it plugged in untill 100% and remove it directly afterwards or should i leave it there?
    Attached Thumbnails From 30 to 0 percent in less than 10 mins-screenshot_2015-12-17-19-30-20.jpg
    12-17-2015 11:42 AM
  10. Adel Fakhry's Avatar
    Attachment 210135
    12-17-2015 11:46 AM
  11. TY_THE_DROID_GUY's Avatar
    Do another wipe cache partition from the android boot screen, reboot phone, then go into settings/advanced calling and activate advanced calling (it's free), then turn it on for voice and video. This literally has added hours to my note 5 battery life. When I first got the phone a month ago, I had similar issues (4 hour battery life from 100 percent, extremely overheating, ect.) Now my phone NEVER gets hot. At all. My battery will last almost 10 hours now, and that's with heavy usage. Hope this helps.
    12-17-2015 11:56 AM
  12. TY_THE_DROID_GUY's Avatar
    Always unplug your phone as soon as it reaches 100 percent.
    12-17-2015 12:03 PM
  13. NickA's Avatar
    No need. You can't overcharge the battery. I've been leaving my phones plugged in overnight for years with no issues.
    LegalAmerican, hub1 and Aquila like this.
    12-17-2015 12:22 PM
  14. clevin's Avatar
    you can't overcharge the battery, but a battery staying at high voltage (high percentage) degrades faster over time. I would never suggest leaving the phone on the charger overnight, especially with Note 5 whose battery cannot be replaced.
    12-17-2015 12:55 PM
  15. LegalAmerican's Avatar
    If the phone can't handle being plugged in overnight, there's bigger problems than battery degradation. These phones can do EVERYTHING but they can't sit plugged in overnight? I don't buy that. Everything I've read about battery degradation shows that batteries will degrade in time with or without doing this practice, and that is why so many freaked out about a non-removable battery.
    hub1 and Kbrulee like this.
    12-17-2015 01:58 PM
  16. maskedcarrot's Avatar
    Usually I see everyone give the advice to actually turn Advanced Calling OFF because it causes other issues. You're the first person I've seen who suggested turning it ON.
    12-17-2015 10:21 PM
  17. TY_THE_DROID_GUY's Avatar
    I know, that's what everyone on this forum seems to be saying, but I found this fix from another forum and it seriously works. No, the advanced calling doesn't seem to make the calls any clearer like it's supposed to, but my battery lasts all day now. Don't believe me? Try it yourself. I should also clarify, when my battery was draining in 4 hours it was due to cell standby. It'd say 80 percent of battery was due to that. Now cell standby doesn't even show on my battery report.
    12-18-2015 07:45 AM
  18. TY_THE_DROID_GUY's Avatar
    Of course they can stay plugged in overnight, it's just better in the long term if you take care of your battery, like the guy above said, it's being at that high voltage all night, over and over again, that will destroy your long term battery life.
    12-18-2015 07:48 AM
  19. clevin's Avatar
    try read something with lab test data, rather than just imaginary things
    How to Prolong Lithium-based Batteries - Battery University
    12-18-2015 08:39 AM
  20. LegalAmerican's Avatar
    I'm not sure I know how to read imaginary things, but thanks for the suggestion. Now I guarantee you can find another source as legit as the one you posted, proving the opposite. I'm not saying there isn't research out there to backup the nonsense you say, but it's the internet. Not everything is accurate or true.
    For every source showing that plugging in a phone overnight is bad, there will be another that says it's harmless. And both will be from trusted sources. Ultimately, yes i'm sure there is battery degradation "in time" when you leave the phone plugged in. Why? Well because batteries degrade in time no matter what the treatment is. Also, by the time the battery is shot from plugging it in and/or simple life expectancy, we'll all be upgrading to a new device anyway because practically no one keeps their phones long enough for this to be a problem.
    hub1 and alfstoria1 like this.
    12-18-2015 08:53 AM
  21. Aquila's Avatar
    Moderator Note: If anyone wants to help the OP, feel free. Arguing over barely tangentially related things is annoying.
    Laura Knotek likes this.
    12-18-2015 02:42 PM
  1. Replies: 5
    Last Post: 03-02-2016, 04:21 PM
  2. How to copy apps to new Galaxy S5?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 12-17-2015, 03:34 AM
  3. Want to buy AT&T SIM for Nexus 6P, where can I buy it?
    By Matthew Briggs in forum Nexus 6P
    Last Post: 12-16-2015, 10:35 PM
  4. can i upgrade my android tablet to 4.3
    Last Post: 12-16-2015, 08:37 PM
  5. Warranty for dust in the rear camera?
    By bonsly16 in forum Samsung Galaxy S6
    Last Post: 12-16-2015, 08:02 PM
