1. darththerinna's Avatar
    So I recently proclaimed an AT&T Note 5, in which the first thing that I did to the device was unlock it and pop in my Sim Card from my LG G4, which belonged to Verizon Wireless.
    Now here's what I'm asking, the data services work fine. Obviously calls and texts aren't working because this phone does not contain a CDMA antenna, HD calling has been enabled so the feature to be able to call using my LTE phone should be working, however there are no settings on the Note 5 in order to initiate HD Voice or VOLTE.
    What suggestions do you guys have to getting this to properly work? I know AT&T Has HD Calling, so there isn't an issue there.
    12-18-2015 08:22 PM
  2. dpham00's Avatar
    Verizon could have specific requirements on hd calling that the att version doesn't have.
    12-19-2015 08:38 AM
  3. itguyjax8430's Avatar
    I second this, I think that the Verizon HD call in settings are different inside of the Verizon Galaxy Note 5. It wasn't just called HD Voice it was in some kind of sub setting that you had to turn advanced calling feature on or something like that on the Verizon model. I don't think that you would be able to use the HD Voice on the AT&T Note 5.
    dpham00 likes this.
    12-19-2015 08:41 AM
  1. When my Note 4 gets to 30% left it will die. Do I need a new battery?
    By Muffdawg69 in forum Samsung Galaxy Note 4
    Last Post: 08-14-2017, 12:24 PM
  2. Note 3 stuck in a boot loop
    Last Post: 12-18-2015, 08:00 PM
  3. How can I get my Verizon Note 3 connect as media device NOT installer?
    By IT_Architect in forum Samsung Galaxy Note 3
    Last Post: 12-18-2015, 07:55 PM
  4. Streaming issues on Nexus 6P.
    Last Post: 12-18-2015, 06:25 PM
  5. Device will not unlock when swiped, why?
    By AC Question in forum Samsung Galaxy Tab A (8 & 9.7)
    Last Post: 12-18-2015, 05:47 PM
