1. Trees's Avatar
    Is there a way to silence sound when a call is incoming? When I get calls from an unknown number I just let it ring, and if a "real" call, then it can go to voicemail.
    While the call is ringing, swiping down on the notification bar to expose the sound control - does not work. The dailer screen has focus. Do I need to minimize the dailer screen to expose a home screen so that I can then change sound from on to vibrate?
    12-30-2015 11:46 AM
  2. MizWylie's Avatar
    I'm assuming you want to silence a call once you look at the caller ID. I usually just volume down button and it silences the call and allows it to go to voicemail.
    Posted via the Sapphire Doom Note 5
    Trees likes this.
    12-30-2015 12:32 PM
  3. tubbz the bull's Avatar
    Turn ur phone face down or volume down
    Trees and Delirious D like this.
    12-30-2015 01:31 PM
  4. Trees's Avatar
    Both great suggestions. I'll try the volume down while on the go, and the face down while stationary or when a suitable flat surface is available. I forgot all about the face down option from earlier Notes.
    12-30-2015 06:11 PM
  5. Delirious D's Avatar
    I flip my phone upside down. I believe its a setting you might have to enable.
    Trees likes this.
    12-31-2015 08:51 AM
  1. How do I change the default email linked to my cloud account?
    Last Post: 12-30-2015, 11:41 AM
  2. How can i conect my samsung note5 duo sim to metro pcs
    Last Post: 12-30-2015, 11:37 AM
  3. Replies: 0
    Last Post: 12-30-2015, 11:30 AM
  4. How do you add a contact to your phone?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 12-30-2015, 11:09 AM
  5. How can I reinstall my OS to Huawei Honor 7?
    By AC Question in forum Honor 7
    Last Post: 12-30-2015, 11:01 AM
