1. houhou123's Avatar
    So when the s pen is on the note 5, I can still feel it, it doesn't align with the body of the note 5, is this by design or it's a faulty one.
    can anyone with galaxy note 5 answer this question.
    12-31-2015 10:49 PM
  2. dennisharrison's Avatar
    If you're talking about it slightly poking out beyond the radius of the bottom right corner, that's normal. It should be SLIGHT. If it's poking out somewhere else, that's wrong. Hope this helps
    12-31-2015 11:33 PM
  3. JohnnytheK's Avatar
    How about a picture?
    01-01-2016 12:23 AM
  4. onlysamsung6's Avatar
    My spen is slightly higher near the back and right side as the actually phone is slightly curved but its normal
    01-01-2016 01:11 AM
  5. H3aTeRzz's Avatar
    Be sure that you're "clicking" it all the way in. Its designed like an ink pen, that you click to engage the point of it.
    01-01-2016 06:20 AM
  6. russel5150's Avatar
    I think i see what your talking about, and yes they are like that.
    The reason is if it was bent slightly to match the curve of the phone perfect, you wouldn't be able to put it in either way. What i mean is the curve it would need would make the pen have to be exactly placed, instead of being able to fit either way. (As long as pointy end goes first lol)
    Sent with my white Note5 with nonremovable back and no SDcard!
    01-01-2016 08:56 AM
  1. Does the Gear S smartwatch work with LG v10 smartphone?
    By william63 in forum Samsung Gear S
    Last Post: 01-03-2016, 10:01 AM
  2. Samsung Galaxy Note 5 not recognized by computer
    By Centuries Incorporated in forum Samsung Galaxy Note 5
    Last Post: 01-02-2016, 08:47 AM
  3. I have an AT&T ZTE phone with straight talk
    By frank1001 in forum Ask a Question
    Last Post: 01-01-2016, 03:16 AM
  4. Obb file install on note 5
    By Redxjak in forum Samsung Galaxy Note 5
    Last Post: 01-01-2016, 03:06 AM
  5. I ran my Note 5 through the washer. What do I do?
    Last Post: 12-31-2015, 09:07 PM
