1. AC Question's Avatar
    Hi,
    I just got Note 5 before a week. After using it a while, I found that my phone LED notification is not working for all the colours like Yellow, Pink, White.
    LED notification is working fine with BLUE, RED, GREEN but not for other colours.
    I set different colours one by one in WhatsApp LED notification (Setting - Notification - LED), but not all are working and I see mixing of two colurs in case of Yellow, Pink, White.
    Any Idea why ? S6 and Note 5 both has RGB sensor but I got above issue in my Note 5 while my friend's S6 is showing all the LED colors.
    Any help would be appreciated,
    Thanks,
    Dave Chintan.
    Kerri Fisher likes this.
    01-07-2016 06:00 AM
  2. dpham00's Avatar
    Mod Note, I will move this to the n5 forum for more visibility
    01-07-2016 06:48 AM
  3. Kelly Kearns's Avatar
    If I'm not mistaken, you will need something like the Light Flow app to get the other colors. I'm not sure about that app now, but a couple of years ago it caused a lot of problems with phones.
    01-07-2016 05:58 PM
  4. Chintan Dave's Avatar
    at Kelly: Whatsapp has official inbuilt functionality to set the led notification color, which in my case now wokring for colors except RGB.
    I also tested Light Flow and LED Blinker but same issue with them for those colors.
    01-08-2016 02:10 AM
  5. Kelly Kearns's Avatar
    I understand that about Whatsapp but I had to use lightflow for other colors.. It was either my Note 4 or Note 5. I ended up removing it though, I only really wanted it to turn off the blinking while charging.. So that is probably an indication it was for the N5.
    This phone might only display those colors. In fact I just installed an app called LED color tester and it really didn't display those other colors at all.
    01-08-2016 01:09 PM
  6. kcalmol's Avatar
    The 5.1.1 update to Samsung phones altered the notification process such that there are issues displaying the LED colors correctly. Lightflow and others have a workaround, but it's still problematic. I'm hoping Marshmallow, when it eventually comes, will resolve this issue.
    01-08-2016 06:27 PM
  7. Chintan Dave's Avatar
    Thanks Kelly for testing this and confirm the same issue on your Note 5.
    I think its the Samsung Software issue but not hardware as Note 5 has the same sensor as Galaxy S6 and on S6 this is working fine. It just a need proper combination of RGB colors to display other colors. and this combination is not correct in case of Note 5 software.
    agree with kcalmol.
    01-12-2016 08:13 AM
  8. mariusfilip's Avatar
    i installed light manager on my s6 and it's working without a problem, the only thing you have to do is disable the in-app led notification for the apps you enable in Light manager Note 5 LED Color problem-screenshot_2016-01-11-11-32-11.jpg
    01-12-2016 10:07 AM
  9. kcalmol's Avatar
    I use the on-screen option in the LED Blinker Notifications app, and it works perfectly. That's my workaround until I give Lightflow another shot with MM.
    01-12-2016 09:25 PM
  10. Chintan Dave's Avatar
    Thanks Mariusflip and kcalmol.
    Acutally this problem is only with Note 5 (and with some specific software build). In my note 5 software, there is also not Quick shortcut of Mobile data ON/OFF button in notification bar. It was not present there ever yet.
    01-18-2016 10:11 AM
  1. Big Wall Charger Problems
    Last Post: 01-07-2016, 07:11 AM
  2. Backup problems
    By SorryNotSorry in forum Ask a Question
    Last Post: 01-07-2016, 06:56 AM
  3. Problems with Nexus 4
    Last Post: 01-07-2016, 06:54 AM
  4. Replies: 1
    Last Post: 01-07-2016, 02:45 AM
  5. Problem idol 3 5.5 *freeze and restaart*
    By DivitarovAleksandar in forum General Help and How To
    Last Post: 01-07-2016, 01:17 AM
