1. AC Question's Avatar
    my note 5 notification volume slider does not give a sample sound when using the main volume rocker button followed by the little gear on the far right of the ringtone volume slider pop up. it use to do it and now not any more. Has anyone ran into this issue? Any suggestions as to how to fix it?
    01-08-2016 03:58 AM
  2. AlphaTango414's Avatar
    When using the volume rocker to change the Ringtone volume, it will give you that sound you are talking about.
    But, when you use the slider to adjust the Ringtone volume it does not make any noise. Neither does any of the other slider adjusters for media, notifications, and system.
    5.1.1 is the cause of this.
    01-08-2016 04:25 AM
  1. Whats the difference between sent & delivered
    Last Post: 01-02-2017, 06:16 AM
  2. Replies: 4
    Last Post: 01-10-2016, 10:23 PM
  3. Replies: 1
    Last Post: 01-08-2016, 07:58 AM
  4. Replies: 1
    Last Post: 01-08-2016, 07:57 AM
  5. Replies: 1
    Last Post: 01-08-2016, 07:56 AM
