Its so much easier to pull out my card....I just haven't been happy with it. It won't allow me to uninstall and if i pick force stop it eventually comes back. I just don't want it running, or have that little tab on the bottom of my screen.
Will the Package Disabler app available in the Playstore serve your purpose?
Just disable it, that's what I did.
How did you disable it? It doesn't have the disable option in the app manager, and continues to update and launch itself despite my uninstalling to factory.
It is driving me nuts.
If you go into the app and turn off simple pay, the tab will not show. If you can uninstall or disable it within app manager, I think you'll need package disabler.
