1. throssel's Avatar
    So I use the standard samsung fast charger and cable that comes in the box. If I plug it in, it just says it's regular cable charging. I have to unplug it and plug it back in about 15 times until it finally will say fast charging, otherwise it takes a long time to charge. It's quite annoying and I'd like to know if anyone else is also having this issue. Do you think I should switch the cable?
    Gold Platinum Galaxy Note 5
    02-12-2016 11:16 PM
  2. angrytentpole's Avatar
    It's likely a cable issue.
    I had the same issue until I bought an aftermarket cable and charging unit and it now fast charges every single time I plug it in.
    I'm pretty sure a few others here have swapped the cable only and had the issue solved.
    02-12-2016 11:34 PM
  3. Mariah Richardson's Avatar
    I have this exact same issue, it's extremely frustrating! I just tried what the above post suggested, changing the cable, and my phone instantly started to fast charge :-) so yes, do that!
    02-13-2016 07:29 AM
  1. Note 4: Font not supported
    By _YoKolorMeBadd in forum Samsung Galaxy Note 4
    Last Post: 02-04-2019, 08:51 AM
  2. Replies: 0
    Last Post: 02-12-2016, 10:01 PM
  3. Why is my battery draining so fast?
    Last Post: 02-12-2016, 09:30 PM
  4. Will the pedometer work when the phone is in your hand?
    By mattl2 in forum General Help and How To
    Last Post: 02-12-2016, 09:09 PM
