1. Veronica98's Avatar
    Is therected any way I can tap anywhere on the screen to take pictures.
    Just got this phone today. Am about to go exchange it if I can't.
    Thanks
    02-20-2016 06:55 PM
  2. NickA's Avatar
    Not that I can see. You can probably download a camera app from the Play Store that gives you that capabilities.
    02-20-2016 08:26 PM
  3. jboogie1289's Avatar
    Thanks
    Why not enable the voice option where you can say certain words to trigger the device to snap the pic. Seems better than having to touch the screen, which makes the shot a lot less stable.
    02-20-2016 09:14 PM
  4. veggie59's Avatar
    I always enable the "cheese" feature.
    jboogie1289 and debdroid1a like this.
    02-20-2016 09:40 PM
  5. jnew619's Avatar
    Thanks
    For the front one their definitely is idk about the rear I'm sure their Is
    02-20-2016 09:56 PM
  6. JJ Jones's Avatar
    You can enable use if volume buttons to take a pic also
    From my AT&T Platinum Gold Note 5
    02-21-2016 10:45 AM
  7. beh's Avatar
    Touching the screen when using the camera is better used for specific area focus. Voice control of the shutter is a much better way of getting the picture you want with less chance of camera shake or framing errors IMO.
    debdroid1a likes this.
    02-21-2016 11:54 AM
  8. ShaggyKids's Avatar
    Mine came with a widget that has SNotes, the camera and like 3 other apps or functions. It's rectangular shaped.
    02-21-2016 04:06 PM
  1. Note 5 Camera lens broken
    By jerrycau123 in forum Ask a Question
    Last Post: 02-26-2016, 04:57 AM
  2. Adding samsung briefing to 2nd user home screen
    By skrigg in forum Samsung Galaxy Tab S2
    Last Post: 02-20-2016, 07:08 PM
  3. Why is my front camera not working?
    Last Post: 02-20-2016, 06:49 PM
  4. How can I find out if my Samsung Galaxy s4 edge is unlocked
    Last Post: 02-20-2016, 06:18 PM
  5. Samsung Galaxy S5 won't let me update software
    Last Post: 02-20-2016, 04:33 PM
