04-29-2016 10:10 AM
123 ... 2345
tools
  1. sandy river's Avatar
    Oh. And i just realized my phone depleted faster than usual. But i'm not sure too.
    So let's say my phone at night (12am) is 100%, in the morning (7am) it becomes around 90% while data connection is on (4G).
    Do you think it's normal?
    03-12-2016 07:53 PM
  2. carlos12001's Avatar
    A little over 1% per hour on lte depending on conditions, I'd say it's not bad. But I'd charge it overnight.
    03-12-2016 08:54 PM
  3. sandy river's Avatar
    And the estimation usage time is around 14 hours on 100%.
    03-12-2016 10:28 PM
  4. carlos12001's Avatar
    I don't know man, dont think too much about it. Just use it.
    debdroid1a likes this.
    03-13-2016 09:50 AM
  5. guacapoli's Avatar
    something is seriously wrong with my verizon note 5 battery life after the marshmallow update. I barely used my phone in a half hour time period and it went down 30%. And that's with disabling any and all bloatware with disabler pro.
    I don't know what to do, I did a factory reset when I upgraded to marshamllow. Right now I can't live with this kind of battery life for my job.
    03-14-2016 02:40 PM
  6. carlos12001's Avatar
    100%-30% in a half hour?
    03-14-2016 08:34 PM
  7. wendemi's Avatar
    I don't really have any problem with my battery... But can anyone tell me what the 10250 in the battery consumption is about? First time I ever see it.
    Attached Thumbnails Note 5 battery life sucks - How many are having to charge their phones more than once a day?-1592.jpg
    03-15-2016 12:41 AM
  8. Trees's Avatar
    That could be an App UID, or user ID. The discussions below are older, but help provide some background details on App UID. For some reason, your phone's battery stats decided to show the App UID instead of the app's name. The way I'd think of this is that the app's IP address "192.168.0.1" was shown instead of it's friendly name "www.awebsite.org". The IP address and friendly DNS name are made up for this example.
    Rebooting the phone may help clear that up. An app like GSam Battery Monitor will show the App UID in App Usage\App Detail. 10256 is the App UID for Flipboard on my Note 5. There may also be apps in Google Play that can query and list all App UIDs, or if you have a Terminal app installed, then that could be used to list out the App UID as suggested in the discussions below.
    How UID of an app determined during install in Android? - Stack Overflow
    applications - How to know app name by UID - Android Enthusiasts Stack Exchange
    03-15-2016 06:39 AM
  9. alejovh1's Avatar
    I'm getting almost 5 and a half hours of sot on my note 5. With most of the time streaming Netflix over lte. Really happy with this one, hope you sort out what's draining yours.
    Matt Behnken and ToddS71 like this.
    03-15-2016 08:20 AM
  10. NexusGirlX's Avatar
    So I have one app installed on this phone and decided to take it to work with me plus I had my S7 Edge with me to use because I knew the Note 5 would not last an entire 8 hr shift.
    The Note 5 was at 43% battery life left after 6 hrs. I finally had to turn it off because I knew it wouldn't last till I got home from work. Screen time usage was 47 minutes. I turned it back on when I got home late this morning. at about 1AM. Battery was at 33% before I went sleep. Woke up two hours later and it was at 15%.
    This is the worst phone I have ever owned.
    Matt Behnken likes this.
    03-19-2016 09:05 AM
  11. Trees's Avatar
    How is the cell signal in your work building location? Where I normally sit the signal is fair to poor (~ 100 dBm or higher) and ranges from 1-2 bars LTE to 3G). Poor cell signal could account for rapid battery drain. Even with that, I usually get home around 6pm or so with 60% or higher (depending upon SOT and app usage), and this is with off charger at 0530.
    Are you still running a custom ROM? In my experience most custom ROMs are well optimized and have little to no bloat (thus better battery life than stock), but if there is a different or tweaked kernel, or other system/UI tweaks those could impact battery life unexpectedly.
    03-19-2016 09:17 AM
  12. Matt Behnken's Avatar
    went to bed last night and forgot to charge my note 5 which was fine since it was at 95%. Woke up and Note 5 was 90% some eight hours later. I would factory reset your phone. I had location, wifi, bluetooth, nfc, sync, all enabled. I have about 80 apps. I can drain the battery though during the day with about 4 hours screen time at full brightness. Spotify doesn't really drain the batter so much as screen on time with full brightness. I "optimize" almost every app besides 1 game and snapchat. If the battery drains like that in stand by after a factory reset, I would return it.
    03-19-2016 02:08 PM
  13. NexusGirlX's Avatar
    This is the factory reset. This is why I had only one app installed. I've owned it for two months now and it's been rooted so the warranty is void.
    I don't think it was this bad when I got it. If I root it, my battery life is incredible but then it reboots on most phone calls making it unusable for that purpose.
    03-19-2016 02:58 PM
  14. NexusGirlX's Avatar
    So as I've said before, as long as my phone was stock, I would get poor battery life making me think the problem is not with the phone. When rooted, I could get the same or better battery life as my S7 Edge which is excellent. The problem with the root was my Note 5 would reboot during phone calls which is a common problem with some of the custom kernels out there that you need to root the phone. I found one now that says that reboot problem was fixed so I'm gonna take this phone out with me tonight and see how it goes making calls. I tried a few just now and it didn't reboot at all.
    I don't mind staying rooted because it's fixing my battery problem. I was only trying to go back to stock because of the rebooting problem.
    03-19-2016 03:38 PM
  15. Matt Behnken's Avatar
    yeah, i realized you're experienced from all those posts on AC after I replied the first time :/. My note 5 was getting really warm and draining battery on standby really fast when I noticed I had "app optimization" turned off under battery settings. Otherwise, I wish I could fix that broken note.
    dieselhazza likes this.
    03-19-2016 04:55 PM
  16. jlost's Avatar
    Low signal?
    03-19-2016 05:57 PM
  17. Dominick079's Avatar
    The battery life on my Note 5 is better then it was on my Note 4. I take it off the charger at 6 am and when I go to bed around 10 pm I still have around 40% left. I am a moderate to heavy user and use my phone all day long especially when I work Monday thru Friday. I disabled all the AT&T bloatware except the My AT&T app. I also disabled any apps that I have no interest in using.
    Posted Via The AT&T Note 5
    ToddS71 likes this.
    03-19-2016 06:49 PM
  18. NexusGirlX's Avatar
    Low signal?
    T-Mobile has excellent service here. They are the only carrier in my area that can get me LTE at my house so T-Mobile has never been the problem.
    I have two S7 Edge phones and one of my iPhones activated and they all get five bars. Never have any dropped calls.
    I rooted the Note 5 again and after 11 hrs standby, the battery is at 88% and I've been texting and calling people all night. My Note 5 doesn't work well with stock firmware. I wish I knew the answer.
    03-20-2016 01:45 AM
  19. jlost's Avatar
    Holy cow, that's a lot of phones hahaha
    03-20-2016 05:00 AM
  20. NexusGirlX's Avatar
    Well, I just wanted to point out that it's not a T-Mobile signal problem.
    03-20-2016 07:31 AM
  21. ToddS71's Avatar
    I've been getting 12 to 14 hours on time with 6 to 7 hours screen on time with mine. I've heard a lot of people complaining about the Note 5 battery, but I haven't had any issues. My wife hasn't either. Maybe we just got lucky? Makes me wonder if Samsung is making the batteries or buying them from different suppliers.
    msndrstood and debdroid1a like this.
    03-20-2016 12:42 PM
  22. carlos12001's Avatar
    The only logical choice is to unroot it and send it back.
    Edit: oh wait, Knox right?
    03-20-2016 08:39 PM
  23. NexusGirlX's Avatar
    Yah, knox has been tripped. My phone is rooted once again and this time I found a kernel that promised to fix the reboot during phone calls problem, So far it seems to be fixed.
    My phone currently 1 day 7 hrs standby, 3 hrs 40 minutes screen time with 38% battery remaining. This is what I've been looking for. I am getting the same stats on my S7 Edge.
    03-20-2016 11:18 PM
  24. carlos12001's Avatar
    I think it has a lot to do with which carrier version note 5 they have. I recommend greenify, and greenify ALL the apps you don't use frequently.
    Right now I have 2hrs SOT, with 5 hrs standby and 68% left. I'd say it's pretty good.
    ToddS71 likes this.
    03-21-2016 12:23 PM
  25. billykac's Avatar
    As you know, there are so many freakin' variables that contribute to battery usage. Looks like you know what you are doing.
    When I moved to MM, I did a full factory reset (always do) and then I used Package Disabler Pro to kill all bogus apps.
    My N5 has extraordinary battery life. But again, lots of variables...
    Good luck!
    ToddS71 likes this.
    03-21-2016 01:41 PM
123 ... 2345
  1. Replies: 4
    Last Post: 04-17-2018, 11:41 AM
  2. Replies: 2
    Last Post: 09-17-2016, 07:53 AM
  3. Sending app to Oculus Home
    By Aftereffect in forum VR Headsets
    Last Post: 02-24-2016, 07:59 PM
  4. Replies: 9
    Last Post: 02-24-2016, 03:00 PM
  5. Replies: 0
    Last Post: 02-24-2016, 01:57 PM
