04-29-2016 10:10 AM
123 123 ...
tools
  1. Kendel72's Avatar
    Ok I have seen arguments both ways but how many are having to charge their Note 5 more than once a day? I am averaging plugging it up about 3 times a day. Literally within 4 hours of being at work and very light use the battery drops below 50%.
    02-21-2016 09:28 AM
  2. sydneycooper1979's Avatar
    How often do you reboot your device? Clearing your system cache may help. Also downloading an app like GSAM battery monitor can tell you if you have a rouge app killing your battery. Failing all else, a factory reset can help this too. Hope it gets better for you!
    02-21-2016 09:34 AM
  3. ShaggyKids's Avatar
    Yeah that doesn't sound good at all. I charge mine when I go to bed. I'm a light user, too so I'd try those suggestions. Good luck!
    02-21-2016 09:42 AM
  4. Almeuit's Avatar
    Please post some picture of your stats. Something is definitely going on.. It shouldn't be draining that fast.
    debdroid1a likes this.
    02-21-2016 09:43 AM
  5. bassjo's Avatar
    What's the signal quality at your work? If it's borderline this would cause your device to eat throughout the battery.
    02-21-2016 10:28 AM
  6. NexusGirlX's Avatar
    I used to have very bad battery life when I was with AT&T because I could never get very good reception here in Denver. Once I switched to T-Mobile, my battery life doubled and it's been excellent on just about every phone I've owned since on T-Mobile.
    02-21-2016 12:11 PM
  7. Kendel72's Avatar
    Signal quality at work is pretty good and I do run my wifi @ work because I have a router in my office so I try to cut back on any data I use there. I am attaching screen shots to look at.
    Attached Thumbnails Note 5 battery life sucks - How many are having to charge their phones more than once a day?-6334.jpg
    02-21-2016 12:41 PM
  8. wrich2005's Avatar
    I've had the best luck with 6p battery life I'm using a Note 5 now but I have my doubts
    02-21-2016 01:26 PM
  9. robonik's Avatar
    There is definitely something haywire with the OP's phone or settings. I use mine in business, frequently for 9 to 11 hours a day, phone, email, etc. One charge per day and haven't gone below 40% yet, mostly 50%.
    02-21-2016 01:56 PM
  10. Kendel72's Avatar
    Yeah I pre-ordered my phone when they first came out. I have taken it back to Verizon and the lil punk salesman said well I'm surprised you are getting 8hrs out of it. Called Samsung and all they wanted to do was tell me things to extend battery life, kept telling them it wasn't gonna help because the battery is junk.
    02-21-2016 03:54 PM
  11. Trees's Avatar
    I can easily get eight hours. The GSAM screenshot appears to be a portion of the apps, so if you can show more that would help to better understand if there's an app that is consuming battery. How is the cell signal at work, home, or other frequently visited places? Poor signal can definitely drain battery as well.
    02-22-2016 06:36 AM
  12. bassjo's Avatar
    So on my note 5 I'm using package disabler and have the junk that Samsung and Verizon like to cram in our phones disabled. I use darker wallpapers, and the dark material theme from the theme store, I have the screen brightness set to auto. Among the apps disabled are Instagram, Facebook, and Google +. Instead I have their web pages saved on the home screen, since making these few changes my battery life has gone through the roof. I take it off the charger around 0600 and usually don't plug it back in until around 11:00 pm. At this point, I've been on the battery for approximately 17 hours and the battery stats day I have another 12 hours to go.
    02-22-2016 07:07 AM
  13. burwil's Avatar
    This reminded me to look at GSam this morning and I discovered that Go Weather App was using 1% of all my apps battery power. And I don't use it. I was experimenting with Next Launcher (which is just an invitation to sales spam IMO), uninstalled it, but failed to installed the weather app. The miserable thing was still working in the background. So now that's gone. GSam is very useful. Over time you can collect apps and forget about them. Doesn't mean they stop using juice. Also, Doze works IMO. DL and give it a try. Some form of it will be in our next OS update.
    sydneycooper1979 likes this.
    02-22-2016 07:41 AM
  14. Kendel72's Avatar
    The other shot
    02-22-2016 09:53 AM
  15. Trees's Avatar
    What are the top % apps in GSAM. The ones I see are 1% or less. There should be some apps that use more than that.
    02-24-2016 06:21 AM
  16. pharmacy21's Avatar
    The problem is the Facebook app. I was going to sleep with 100% charge and waking with 60%. Uninstall the FB app and then just add the mobile site from chrome to your home screen. The battery went from being projected to last 8 hours to over 30 hours.
    02-24-2016 12:25 PM
  17. NexusGirlX's Avatar
    My Facebook app is always at the very bottom of the usage stats. It never uses more the 1% and has never been a problem for me on any of my phones.
    My Note 5 dropped 2% over night.
    02-24-2016 12:27 PM
  18. OceansBorder's Avatar
    Same problem here too. I usually clear the cache of several running systems but I am not happy with the battery life.
    02-24-2016 05:11 PM
  19. zmann's Avatar
    I get at least 10 hours everyday with moderate use.
    02-24-2016 05:21 PM
  20. pharmacy21's Avatar
    also could of been my weather channel app because I got rid of that as well. Used the phone all day since 8 am and am only at 72% . Great battery life now.
    02-24-2016 05:38 PM
  21. pharmacy21's Avatar
    02-24-2016 05:38 PM
  22. Soylent_Green's Avatar
    I usually only charge once per day, unless I am going out after work then I will top it off when I get home which is usally around the 80% mark, granted I don't use my phone much at work because it is frowned upon.
    02-24-2016 06:15 PM
  23. bassjo's Avatar
    Though in the battery stats it shows up as hardly taxing, I can assure you that the simple of act of "uninstalling" FB, G+, Instagram, and only using the mobile sites has caused my battery life to skyrocket. What I mean is after 16-17 without charging I've still got 30-40% and if I treat it nicely it estimates I could last another 12 hours.
    02-24-2016 06:47 PM
  24. jlost's Avatar
    I get a lot more than my older G4.
    02-24-2016 08:53 PM
  25. TheMatrix31's Avatar
    I never have had Facebook app issues either. Always super low on the GSAM list (along with Messenger). I still removed mine though because I figured maybe something in the Facebook or Messenger app was causing my Android System reading to be sky high but nope. I really need to add those apps back.
    Wish I could say the same about any overnight drain though. Usually around 10-15% overnight for me. Not sure why. I'm on wifi at home too. *shrug*
    My battery life on this phone is incredibly inconsistent for having generally light, consistent usage patterns. I'm really not sure what to make of it. Whatever.
    02-25-2016 01:15 AM
123 123 ...
  1. Replies: 4
    Last Post: 04-17-2018, 11:41 AM
  2. Replies: 2
    Last Post: 09-17-2016, 07:53 AM
  3. Sending app to Oculus Home
    By Aftereffect in forum VR Headsets
    Last Post: 02-24-2016, 07:59 PM
  4. Replies: 9
    Last Post: 02-24-2016, 03:00 PM
  5. Replies: 0
    Last Post: 02-24-2016, 01:57 PM
