1. Taurus71's Avatar
    My screen on my Note 5 is extremely sensitive & overtime I put in my pin it puts in an extra number, so in my wisdom I change my pin to include that extra number. However when I went to access my phone later is continually tells me that the pin in incorrect! I was absolutely certain it was correct & don't understand why I can't open it!
    Anyway since then I used my samsung account to unlock my lock screen, but when I go into security to remove the pin, it tells me I must enter the pin first in order to change my security!!! GRRRR!! If I could get the pin right I wouldn't need to change it, how do I clear the pin please?? Someone help!!
    02-24-2016 09:45 PM
  2. JohnnytheK's Avatar
    I did the same when entering a backup for my finger print. I knew the pin it was one I've used before. I tried enough times that a message from Google asked me if I wanted to change my pin. Hell yeah! It asked me my security questions. And let me reset my pin and log on.
    02-24-2016 10:13 PM
  1. Bluetooth range Note 5 paired to Gear S2
    By ShaggyKids in forum Samsung Gear S2
    Last Post: 03-10-2016, 02:21 PM
  2. My note 3 virus
    By AC Question in forum Samsung Galaxy Note 3
    Last Post: 02-25-2016, 01:58 PM
  3. Note 4 works with Galaxy Gear VR Consumer Edition
    By ChetManley762 in forum Samsung Galaxy Note 4 Accessories
    Last Post: 02-24-2016, 09:31 PM
  4. Replies: 0
    Last Post: 02-24-2016, 07:59 PM
  5. Where on the Note 5 can you find system info?
    Last Post: 02-24-2016, 07:55 PM
