1. Issemann's Avatar
    Within the past few days, something happened where Nova Launcher just freezes up for about 30-40 seconds - or sometimes totally locks up. I'm not sure what's causing it though. There was a recent update to TeslaUnread, but these issues are still happening even after uninstalling it. Using stock Touch Wiz has no issues. Anyone else experiencing the same??
    02-29-2016 03:20 PM
  2. bassjo's Avatar
    Nope, I don't have Tesla Unread installed.
    02-29-2016 08:08 PM
  3. trucksmoveamerica#AC's Avatar
    I have both and no issues
    02-29-2016 10:08 PM
  4. Harlemknight's Avatar
    Yes, it has happened to me once.
    02-29-2016 10:13 PM
  5. Rmbrown1964's Avatar
    I have both installed and works great on my Note 5
    02-29-2016 11:39 PM
  6. anon(153966)'s Avatar
    Maybe uninstall Nova (I know you've done this already), reboot, and then reinstall...
    Also, when you reinstall, DON'T restore your Nova settings. Use as is for a few hours, see how it operates, then, restore your Nova settings. Maybe something in your settings, is causing an issue.
    Issemann likes this.
    03-01-2016 07:53 AM
  7. Issemann's Avatar
    I found the problem last night.... It was the Google Now widget. Once I removed it, everything went back to normal! ๐Ÿ˜Š
    anon(153966) and dpham00 like this.
    03-02-2016 08:22 AM
  8. bluedragon1971's Avatar
    The only issue I have was the unread email count. Every once in a while, it would show 999+. As soon as I launched email, it would correct itself. I haven't seen this occur since the tesla unread update.
    03-03-2016 10:53 AM
  9. Issemann's Avatar
    Just got a note from TeslaCoil Help stating that this is a known issue with their beta version of NovaLauncher. So you can opt out of the beta program and revert to the stable version to get rid of the issue.
    anon(153966) likes this.
    03-03-2016 11:40 AM
  10. dpham00's Avatar
    Weird, but glad it worked for you
    03-03-2016 07:46 PM
  1. Replies: 11
    Last Post: 09-12-2016, 11:40 PM
  2. Replies: 2
    Last Post: 08-12-2016, 09:41 PM
  3. Note 3 to Note 5? Thoughts,
    By sardar615 in forum Samsung Galaxy Note 5
    Last Post: 03-15-2016, 02:14 PM
  4. Why is my Note 5 No Longer Fast Charging?
    By AC Question in forum Samsung Galaxy Note 5
    Last Post: 02-29-2016, 06:18 PM
  5. Anyone getting burst of pictures with just a light tap on screen?
    By isabel95 in forum Samsung Galaxy Note 4
    Last Post: 02-29-2016, 03:05 PM
