I've been using the S5 since last May and while it's a great phone, I'd like to have something newer. I was considering the Note 4, but then I was really enjoying the Note 5 when I was playing with it at the store recently. My number one major concern is the battery life. I've heard mixed things about the battery life on the Note 5. I usually get through about a day or so without having to charge my S5. I do use it quite a bit, but I'm not a power user who relies on it for a business or work or such.
I have T-Mobile so they can be quite pricey, but the the Note 5 is 50 dollars off right now. And sadly I believe they discontinued the Note 4 recently because it's no longer available on their website except under certified pre-owned. If I really wanted to could probably find it cheap unlocked on amazon or ebay, but the Note 5 is so tempting...
So what do you guys think? Should I go with the Note 5 over these other phones? Is it a worthwhile upgrade?
