1. AC Question's Avatar
    I have tried with the USB2 output, no luck. Tried a Microsoft Wireless Display Adapter (Miracast), no luck. Contacted Samsung..spoke with 3 different people and all 3 said it was not possible. I find it hard to believe NOTE 5 can not be connected. I know the micro USB no longer has MHL, but there has to be a way...
    03-01-2016 11:46 AM
  2. Trees's Avatar
    Looks like Bluetooth is an option for Android. Maybe that will work? For USB, the Note 5 would need to be in MTP mode rather than Installer Mode. Installer Mode comes up by default.
    AppRadio 4 (SPH-DA120) - Smartphone Receiver with 6.2" Capacitive Touchscreen Display, Apple CarPlay&#8482, Bluetooth®, Siri® Eyes Free, Android™ Music Support, Pandora®, FLAC Audio Support, and On-Screen Access to Compatible Apps | Pioneer Elec
    03-02-2016 06:27 AM
  3. masi0's Avatar
    I have SPH-DA120 and S7 Edge and I can connect it over USB however only apps compatible with MirrorLink can be used
    for example Spotify, Sygic runs smoothly
    04-16-2016 10:13 AM
  4. chronotropic's Avatar
    what did you use to connect your s7 to your appradio 4 sphda 120?
    05-11-2016 09:15 PM
  5. Josay89's Avatar
    I am wondering the same.
    My s7 will not connect it Gets stuck in the mirror link screen and nothing happens on either usb port
    I will be trying a miracast recommended by pioneer I hope it works?I don't want to go back to iPhone.
    09-20-2016 11:34 AM
  1. how i hacked gear vr to increase FOV and IPD
    By kingkong90210 in forum VR Headsets
    Last Post: 06-04-2016, 06:58 AM
  2. Replies: 2
    Last Post: 03-01-2016, 02:00 PM
  3. Replies: 1
    Last Post: 03-01-2016, 11:46 AM
  4. Which phone should I upgrade to?
    By FlorisKnight in forum General Help and How To
    Last Post: 03-01-2016, 11:42 AM
  5. Replies: 1
    Last Post: 03-01-2016, 11:38 AM
