Hello everyone, starting the other day, my Note 5 has been turning off and the battery goes to 0 even if it has 70% battery. When I plug it in to charge, it eventually turns on after a few minutes charging from 0% battery. After the 2nd time, I did a factory restore in hopes of fixing the issue. It seems now that it is still happening and I have no clue why. Also, fast charging never works the first time. Sometimes, I need to unplug and plug back in until it shows 1 hour until full charge. Most of the time, it says 3 hours until full charge which is completely wrong.
I am on the AT&T Next plan and I do not have insurance but surely, this would be covered under warranty, right?
Thank you for the help in advance,
