1. kingredfire's Avatar
    Is it just me or is the paint inside the insertion point for the SPen white unevenly. I am aware there are other white etches inside this part, but this one bothers me because it is uneven. Can you please take pictures of your SPen insertion holes please? ๐Ÿ˜†
    A Concerned Note 5 User
    03-03-2016 05:59 AM
  2. Trees's Avatar
    I think that's normal. I can see white plastic color with a few small dark colored vertical lines. Likely this part of the phone was not painted, so the chance of paint rubbing off should not be there, as I don't see any paint marks or discoloration on the S-Pen that would indicate paint rubbing off from the S-Pen home. I don't think the color difference is anything to be concerned a out.
    03-03-2016 06:22 AM
  1. Don't have option to " open app with" Samsung Galaxy tab e
    By inthegalaxy in forum Android 6.0 Marshmallow
    Last Post: 03-06-2016, 04:06 AM
  2. Afraid someone it looking at my stuff
    Last Post: 03-03-2016, 08:23 AM
  3. Hi, just trying to see if this a common problem with S6 or are we cursed?
    By HateVerizonNSamsung in forum Samsung Galaxy S6
    Last Post: 03-03-2016, 08:17 AM
  4. how to unlock pattern without lossing data
    Last Post: 03-03-2016, 04:59 AM
  5. Replies: 0
    Last Post: 03-03-2016, 04:10 AM
