Anyone else having WiFi issues or the "Update Google Play services" notification popping up after each reboot?
My WiFi connects, but internet won't work over WiFi. Tried clearing cache partition, forgetting network, etc.
Edit: seems to be working fine on my 5ghz network, but not 2.4hz. On to troubleshooting the modem.
Edit 2: So freaking odd, I read up on this and found the following: "It’s been known that the Galaxy Note 5 authentication error can be fixed by turning off the “Bluetooth” while the WAP is enabled, since this will change the frequency on how the both wifi and Bluetooth interacts with one another. Adjusting this should be able to solve the error with the Note 5 Authentication Error problem." Well, I turned off Bluetooth (which was not connected to anything), reconnected to the 2.4ghz network. Works now.
Edit 3: Well, even odder. My WiFi will not work when my Bluetooth toggle is on. Once I toggle off, it works just fine.
