billykac
Now that MM has been running very well on my N5 (I did a factory reset) and all of my required apps are installed and running for days now, I figure this is a good time to reinstall Package Disabler Pro and dump all of the bloatware. I didn't want to do this immediately - I wanted to confirm that all is well on the MM front. Prior to MM, I used PDP conservatively to chuck everything from VZW, all the obvious bloat, and some Samsung stuff I'd never use. I found that it has worked great on the N5, making my battery last way beyond a day for me.
So, have any of you chucked the bloat yet with PDP?
Any issues doing so with MM?
