gsweinberg87
I'm losing 5% overnight. It's been great. When you check battery usage, what is using the battery overnight?
I can't post a photo yet because I don't have 10 posts.
The biggest usage is coming from Android OS.
When did you factory reset?
Does anyone else keep Location turned on? I find it very helpful in locating news, restaurants etc. In my area but want to know does it drain your battery?
Ok good. Thanks for your response.I keep it on. If it has an effect I don't really notice it and it's not enough to cause me to change my usage.
I agree. I try to turn off what I can to preserve battery life but without taking away all the good features of the GNote5.No problem. I am sure someone else will chime in and tell you the exact opposite though. That seems to be the way it is. I think the apps you install and what you are doing on your phone play the biggest role in battery life. That's why some get great battery life and others don't.
Mine is set to power saving modeI keep mine on, but not set to high accuracy unless I really need it. I think it drains some, but like you, I prefer to use those features pretty regularly so it is worth it to me.
I did thefactory reset but not the cache partition. Don't know what or where that is.Anybody who's having problems and has not done a factory reset, I strongly advise to do one and wipe cache partition manually.
I have around 2 to 3 reboots a day also, plus when I'm streaming iheart radio or any streaming music service, once my screen times out or I turn it off manually, it will stop playing or completely close the app since this 6.0 update. Listening to music on my phone is a joke now.
I saw in another thread today in the Note 5 forum where someone discovered that uninstalling the iHeart Radio app stopped the random reboots. Might be worth trying. If I come across that thread will post it here for reference.
