I have tried the regular method to enable the system ui tuner in my note 5 with MM, but have had no success. Anyone know how? I already have dev options enabled.
What us the regular method?
Verizon Galaxy Note5
Yes, but i want to be able to adjust what is displayed in the notification shade.
What is the point in wanting to do this, isn't it for stock Android so you can modify the quick settings in notification tray? Can't you already do that with the edit button on touch wiz?
