1. droidman2177's Avatar
    I have tried the regular method to enable the system ui tuner in my note 5 with MM, but have had no success. Anyone know how? I already have dev options enabled.
    03-04-2016 03:41 PM
  2. Javier P's Avatar
    Have you disabled animations in the developer options? The three values must be set to 0.5x or 1x for the UI tuner to open. If that's your case remember to reboot your phone after changing those values.
    03-04-2016 05:05 PM
  3. Ryano89's Avatar
    What us the regular method?
    Verizon Galaxy Note5
    03-04-2016 08:13 PM
  4. Javier P's Avatar
    The regular method is opening the quick settings and long pressing the settings/cog icon top right until System UI tuner opens.
    03-04-2016 08:47 PM
  5. bbqwings2's Avatar
    What is the point in wanting to do this, isn't it for stock Android so you can modify the quick settings in notification tray? Can't you already do that with the edit button on touch wiz?
    Ryano89 likes this.
    03-04-2016 08:49 PM
  6. droidman2177's Avatar
    Yes, but i want to be able to adjust what is displayed in the notification shade.
    razortaz18 likes this.
    03-05-2016 03:36 AM
  7. wrich2005's Avatar
    All of Samsung's settings that you can control are already available in the regular settings. Only stock Android implements the ui tuner to my knowledge.
    03-05-2016 06:59 AM
  8. droidman2177's Avatar
    Ok, thanks for the input.
    03-05-2016 07:59 AM
  9. Royce Simpson's Avatar
    One feature of the System UI Tuner that Samsung has skipped is the "embed battery percentage in the icon" functionality. I can't find that anywhere.
    03-07-2016 01:14 PM
  10. tascalun's Avatar
    It allows turning off static notification icons such as Bluetooth so if you want to leave your Bluetooth turned on without having the icon in the notification bar you can. That is not available under standard edit.
    04-19-2016 10:36 PM
  1. Low to mid priced Verizon phone suggestions?
    By Aflaaaak in forum General Help and How To
    Last Post: 03-08-2016, 08:11 AM
  2. Will my voice record on a S4 video?
    Last Post: 03-04-2016, 09:27 PM
  3. My phone is stuck on the Samsung logo , help !
  4. Replies: 0
    Last Post: 03-04-2016, 03:38 PM
  5. Replies: 0
    Last Post: 03-04-2016, 03:37 PM
