1. Kyle Rough's Avatar
    I just installed 6.0 on my note 5. I tried to activate the ui tuner but cannot due to still having the old status bar. The new one is supposed to display your Google profile pic but mine does not. I called Verizon but that were clueless to everything I was saying.
    03-07-2016 02:55 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! The UI Tuner might be specific to Nexus devices only. But you also have to make sure you haven't turned off animations in the Developer Options menu--if you did, then turn them back on, and try again.
    03-08-2016 06:40 PM
  3. Kyle Rough's Avatar
    Hmm that's a good point, I'll look into that. Next question. Before the update when I clicked the power button it would go right to the lock screen with the pattern. Now, it goes to a screen that I need to swipe, then it will go to the lock screen. It will do this with every lock method, not just pattern. I've messed around with the lock screen and security setting for hours but no luck
    03-08-2016 08:05 PM
  4. BBgeeqed04's Avatar
    May need to reboot or look for an answer in another thread. I've seen it, but can't remember where. I don't have the issue you're having. So, it's just a guess.
    03-11-2016 04:29 AM
  1. S7 edge Reception issue
    By limitbreak09 in forum Samsung Galaxy S7 edge
    Last Post: 11-06-2016, 01:10 AM
  2. Samsung Note 4 locking up
    By Chevy5150 in forum Samsung Galaxy Note 4
    Last Post: 04-05-2016, 11:51 AM
  3. Soft Key Issues
    By drummer07#AC in forum Samsung Galaxy S7
    Last Post: 03-08-2016, 08:12 PM
  4. Just switched from iPhone 6 plus to note 5
    By missy8787 in forum Samsung Galaxy Note 5
    Last Post: 03-08-2016, 06:38 PM
  5. Replies: 1
    Last Post: 03-08-2016, 05:53 PM
