1. AC Question's Avatar
    The note 5 will not come on, but the blue led light is blinking
    03-12-2016 11:08 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Does it vibrate or make any sounds at all (e.g., if someone calls your phone)?
    03-13-2016 05:04 PM
  3. mcoomer's Avatar
    When it locks up like that, hold the volume up then the power button. Keep holding them until the android appears then release the power button. When the menu appears, use the volume buttons to scroll up and down them the power button to select "Wipe Cache Partition". Once that finishes, select reboot from the menu. I do the partition wipe periodically and have to say, I think the phones runs better.
    Good luck.
    Mike
    03-15-2016 02:09 PM
  1. I want android lollipop or marshmallow for Coolpad Dozen
    Last Post: 09-09-2016, 11:34 PM
  2. Want list for the Note 6...
    By soldier45 in forum Samsung Galaxy Note 5
    Last Post: 03-30-2016, 01:28 AM
  3. Replies: 1
    Last Post: 03-13-2016, 05:09 PM
  4. zeepad 7.0 won't master reset?
    Last Post: 03-13-2016, 05:07 PM
  5. Does the new Samsung Galaxy S7 have Gorilla Glass?
    Last Post: 03-12-2016, 10:53 PM
