1. Rmbrown1964's Avatar
    I have a Samsung Note 5 and I use nova launcher. I also use the blak UI from the theme store. After I apply the theme my icons do not change like it shows in blak UI. Thanks in advance.
    03-15-2016 10:58 AM
  2. B. Diddy's Avatar
    Themes from the Samsung theme store might not be fully compatible with alternate launchers. Does it work correctly using TouchWiz?
    03-15-2016 11:37 AM
  3. Rmbrown1964's Avatar
    I will try that now. Thanks
    03-15-2016 12:08 PM
  4. Rmbrown1964's Avatar
    Thank you it works. Thanks again
    B. Diddy likes this.
    03-15-2016 12:11 PM
  1. VPN help! - Best solution for Android?
    By android1946 in forum General Help and How To
    Last Post: 11-03-2016, 08:07 AM
  2. gear help
    By welshmikie in forum VR Headsets
    Last Post: 03-15-2016, 04:54 PM
  3. Prestigio 5508 wifi problem, can I get some help fixing this?
    By stoyangv in forum General Help and How To
    Last Post: 03-15-2016, 12:27 PM
  4. S7 edge call receiving and sound issues, can I get some help?
    By Nelleia in forum Samsung Galaxy S7 edge
    Last Post: 03-15-2016, 10:06 AM
  5. Device not found with adb, can anybody help?
    By nababy12 in forum Android 5.0 Lollipop
    Last Post: 03-15-2016, 10:03 AM
